BX25 floor pan
/ BX25 floor pan #1
cthusker
Norfolk, Ct
BX25
Does anyone have a part number for a BX25 floor pan? Mine is rusted out pretty bad and I'd like to simply replace as opposed to trying to fix it... thanks
/ BX25 floor pan #2
You can try this number, may need to be more specific as to which BX25 you have.
Called a step, there are other part numbers depending on model such as K2581-55154.
Part Number K2883-55150
Vendor Kubota
Messick's Price $88.15
Stock Quantity 1
Weight 10.00 lbs
Days to Order In stock
Replaces K2692-55050, K2581-55154
/ BX25 floor pan
Thank you very much and it's most appreciated... :thumbsup:
/ BX25 floor pan #4
For about $15 you can do what I did with a scuff pad on your drill and a can of bed liner.
Before and after.
/ BX25 floor pan
Thanks... I'm going to give that a try at least for now. Mine's in pretty rough shape with rust starting to go completely through with open holes. However perhaps I can salvage it as opposed to spending about a 100 bucks!! Thanks again.. yours looks excellent....
/ BX25 floor pan #6
Back when I bought my L3700SU, if had a plain painted floor board, no rubber mat. I removed it in the first few days as well as the step and center cover..and had them sprayed top and under with Linex....still looks like day 1.
/ BX25 floor pan
I wish I has thought of that because I had my new F150 Line-X'd immediately upon buying it......... that would certainly solve the rust problem!!
/ BX25 floor pan #8
Thanks! Maybe you can pop rivet some sheet metal over the part that is rusting through?
Then give it the scuff and liner treatment. Probably last 10 years or more!
/ BX25 floor pan #9
I like the bed liner idea. My mat is worn out. I have never liked it, hard to clean under it w/o removing it and several mat fasteners are now missing. I need to pull the pan to get to another irritating situation. Good time to remedy it. Thanks for the catalyst.
Ron
/ BX25 floor pan #10
Ron
You are welcome! For an hours work it really is a no brainer. Each time I lifted the mat to hose it off I would think ( I have to do something about this bad situation.)
2020 John Deere 624L Articulated Wheel Loader (A61567)
2020 John Deere...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63118)
2017 Cadillac...
Margaritaville Mini Decorative Truck (A61569)
Margaritaville...
2006 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2006 JLG 600S...
2014 FORD F150 4X4 PICKUP TRUCK (A59909)
2014 FORD F150 4X4...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
