BX25 Brake Conversion?
   / BX25 Brake Conversion? #1
RAECOREP
Ramsey,MN
kubota BX25
Anyone try a left side brake pedal conversion yet? I am going to try it when winter is done. It would be fairly easy if not for BH sub-frame being in the way.
It looks like just the pedal shaft could be cut and new pedal added on same shaft as original.
I will leave the original pedal and just add new on left but not as tall, basically mirror of right side. I think the hardest part will be getting hole in floor correct. Any thoughts on doing this?
Thank you, I already have the mechanical drawings from Kubota. I am going to check price/availability of pedal assy. probably the easiest way to do it, but not as much fun
   / BX25 Brake Conversion? #5
Has anyone tried to make a 2 pedal HST conversion in place of the toe and heel single pedal?
25D has the brake pedal on left side, much easier to use 2 feet than 1 when it comes to "power inching" as I like to call it. There are a few other things that have been improved too. Most of them can be done with aftermarket parts/add-ons to the 25.
Personally I like the single better. I've run forklifts both ways and a single toe-heel seems to agree with me better.
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2013 Ford F-350 XL (A50120)
2013 Ford F-350 XL...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
JLG 1932R 19FT Electric Scissor Lift (A50322)
JLG 1932R 19FT...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
