Oil & Fuel BX25 Bleeder plug purpose
/ BX25 Bleeder plug purpose #1
Moldymike
Kubota bx25
My BX25 has a bleeder bolt screwed inside a larger hollow bolt that connects the fuel line to the fuel injector. Does anyone know its purpose?
/ BX25 Bleeder plug purpose #2
Isn't that to bleed air from the system if you run it out of fuel?
/ BX25 Bleeder plug purpose #3
YES it is referred to as a "banjo bolt", try very hard not to over tighten it if you in fact have to bleed the fuel system. But saying that installing a racor centrifigal fuel filter between the tank and the injection pump prevents this from occuring as the Racor unit has a pair of check valves to prevent an airlock.
If you have to bleed the fuel system you will need to have the copper washers required to replace the ones on the banjo bolt as they are automatically deformed at low very very low torque to seal the fuel system.
