BX25 Backhoe Bucket Pin Stuck
   / BX25 Backhoe Bucket Pin Stuck #11
This is a pin out of the front end loader on my bx25 it snapped while digging/loading rock. took it to the dealer an he said that it is odd for the pins to break cause they are hardened. I asked if I could get a better/stronger one an he said they are all made out of the same material. If you run a file across it it doesn't cut easily.
JJ that's interesting.
It sure depends which person you talk to at the dealer, usually somebody knows something just not everyone.
When I was setting up to replace the pin on my excavator I was going to buy drill rod & some knowledgable TBN members told me I was thinking wrong. I went to a heavy eqpt repair shop and he said same thing, pins are soft. Then when I cut my bent pin out with a sawzall, it was almost like cutting an Oak dowel, so yes it was very soft. Would probably plug up a file, like filing lead. Your pin was hard enough to crack though, can't imagine my pin cracking unless it was bent back and forth like a piece of wire.
Certainly there can be a case where they needed more pin strength and used a hard rod. Maybe if the bushings are replaceable? Thx for clarifying.
   / BX25 Backhoe Bucket Pin Stuck #12
Had the same problem, I kept one hand on the pin and slow raised and lowered the boom up and down while i turned and pulled pin out.
H&S 10-Wheel Rake (A49251)
H&S 10-Wheel Rake...
Miller Welder (A49251)
Elevator (A49251)
Elevator (A49251)
2019 International DuraStar 4300 Adkins Service Truck (A48081)
2019 International...
INOP/NON-RUNNING 2012 Ford F-450 Pickup Truck, VIN # 1FD0W4HT2CEC31215 (A48836)
INOP/NON-RUNNING...
42in Hydraulic Forks Forklift Attachment (A49346)
42in Hydraulic...
