BX25 ALTERNATOR UPGRADE
/ BX25 ALTERNATOR UPGRADE
I forgot to mention, a couple guys ask'd "why". I forgot I want to be able to
use a winch as well. That puppie will kill this little electrical system quickly.
I "think" remember I am horrible at electrical stuff, that if I beef things up
I will get longer use out of a winch.
OK, in post 17 I suggested Keller's site may be wrong, I called and asked and
pleasantly Brad called others and got right back to me advising me indeed the
3A011-74013 is a 60AMP Alt.
Remember the challenge tis to find a plugNplay higher output alternator.
Not take apart mine or change brackets and and and... BX25 owners
forever will reap the rewards if this is doable and w/o problems and hoops
to jump thru.
PS, KennyV, I am posting a lot of my finding in hopes it will help others.
Just maybe someone will hit upon something from my hard work.
I happen to enjoy a challenge. This is w/o a doubt "hard", espically
for an Electricaly HandiCapped Plumber!
/ BX25 ALTERNATOR UPGRADE #23
I think the alternator you found in post 18 has a great chance of being plug and play , we just need to see the plug, you already know the front case is the same part #.
Ray
Ray
Ray, Thanx for the input. Seems like I run to this board too much for solutions,
I dunno if that is good or bad. The useless comments from the peanut gallery
really blow, why do they bother? Anyways, if this is thinking outside the box,
I fired off a RFI to DENSOGLOABAL. Who knows, maybe they will reply w/
many choices w/ part numbers. Here is what I penned to them;
Sirs,
We seek a solution from DENSO!
Currently our project has a DENSO Alternator.
We need more output from a unit with the same frame,
and hopefully same 3 wire plug configuration.
We have a large format picture of your product at this link,
this is what we have;
THE PIC IS ALREADY IN THIS THREAD
Can you Please, recommend part numbers for all higher output
alternators that will be a bolt-in, plug and play replacement
or with little plug modification?
THANK YOU!
/ BX25 ALTERNATOR UPGRADE #25
I am not sure what to tell you -- all
I can say is that a 12k winch uses roughly 3k watts. I dont know of any alternator that will handle that as the battery will always be the buffer. I like your thinking that swapping the alternator is the smallest space upgrade you can do over adding a secondary battery that charges only when tractor is running, but a massive rewiring changes will be made to make the lights, winch, boombox amp, etc to run off that secondary battery with a backup switch to primary. If I know I will be doing this extensively daily, I would take this project on but right now, its not something I want to mess with.
So going back to alternator swapout - just looking at the pics appears it might work, but innards looks much more beefy with the electrical rectifier changes too. I'd visit your local dealer and take a peek at the current models outside.
So I have all notes in one thread, and I think a gent said #6 prior....
notforhire said; " I think the only wiring you would need to change would be the output lead from the alternator to the battery."
If I hang on a winch from time to time I see I need a bigger battery.
I have BX25 Battery notes HERE
/ BX25 ALTERNATOR UPGRADE #28
I know nothing about B size tractors.
I don't know if this may be of some help. Looking at the L3540 specs, if you get a cab model, the alt. size goes from a 40A to a 60A.
I was wondering if the same is true of the B size. Is there a B cab tractor that uses the same engine configuration?
If you go to a second battery you could install a diode set, like ones used in boats with start and house batteries. This stops flow between batteries, but allows one alternator to charge both.
Bill
Bill once agin I say Thank you for your input. Indeed should I
go w/ two batteries there will be another learning curve to hurdle.
Sure would be nice to find a monster battery to fit inside my
space, 7' x 9" x 9" is what I have and I need a 650CCA minimum
battery.
The info I just got says the 60Amp Alt in post 18 is a different plug...sigh.
This pic is the plug for a BX25. Can anyone tell me what the symbols mean?
P=Power? IG=Ignition? L=Lights?
Ugghh...
The first picture is a regulator for a 60AMP Alternator that is 99% sure to bolt into a BX25.
It has two blades to the plug.
This second picture is a regulator for a 40AMP Alternator that is for a BX25.
Can I make this work by making a 60 x 40 electrical pigtail adaptor?
I need to figure out what P IG L mean ...
/ BX25 ALTERNATOR UPGRADE #35
By the time I read through this whole thread, I was like :confused2: :confused: :confused2:
Best of luck with your project!
/ BX25 ALTERNATOR UPGRADE #36
For sure....
This topic has came up in the past, several times... With direct, no nonsense solutions...
this thread changes a simple upgrade into a muddled problem. It really is Not This difficult... & has been easily completed, use the search function. The wheel has already been invented. KennyV
Sorry I do not meet up to your standards!
Wish I was that smart, obviously I am not, if I had the awswers
I would not be here. Sorry I spoiled your TBN experience w/ my
inabilities. If someone had jumped in and interjected a solution
it would have died long ago. To date alls I can do is
post my thoughts in hopes of coming upon a solution.
I believe I have proclaimed my lack of electrical skills
some time ago. Congradulations if you know the
answers, till I see it alls I know is you know the
awnsers and I do not...
I go to GREAT pains to pay it forward on this list.
GrappleOmatic, BX25 Full Cage Rollbar and others. Is
it really to much to seek help from time to time? Perhaps
if I was just a huge vacuum on this list your "complaint"
would be warranted, the facts are I am not, thanx for
nothing.
/ BX25 ALTERNATOR UPGRADE #39
Ugghh...
Is it possible that your tractor doesn't use the P connection? Is your tach. electronic? If you have access to a wiring diagram you could find out if P is actually used.
That alt. could be built to fit many different apps.
I recently replaced an alt. in a friends Ford tractor. The new alt. came with a tach lead. The original didn't have one.
The L is for your Alt. charge light.
IG is to provide field for the alt. and becomes hot when the key is on.
"Can I make this work by making a 60 x 40 electrical pigtail adaptor?"
I would say yes, unless there is something that uses the tach. lead.
My 3240 has an electronic tach. for the PTO. I expect that I would need the P connection on my tractor.
Bill
/ BX25 ALTERNATOR UPGRADE #40
Now you got me curious Artisan. It's hot outside and good time to sit in front of cold computer. Looked on the web in general. People with Truck/Jeep winch questions etc. These are folks with 75-80 Amp alternators already. A lot depends on what type of winch you are focusing on.......... heavy duty, or baby ATV type winches. Here are a couple of sites with some electrical info.
http://www.jeepforum.com/forum/f27/winch-amp-draw-stock-alternator-140033/ (notable quote: You will never be able to install an alternator that will keep up with the draw an electric winch will place on the battery, this is a loosing battle.) Some of the winches will be drawing about 400 amps when working; at idle, motor only, they draw around 55 amps (Ramsey 4.8 HP series wound motor for 12K winch)
How to choose a Winch (See the section on electrical considerations).
So it all depends what you want your winch to do, if light duty work I bet your 40A alternator could work, a lot less hassle.
I am a little wiser now after doing a little looking. Good luck in your endeavors.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
New 50Pc Equipment Key Set (A65579)
New 50Pc Equipment...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
2022 EZ-GO ELITE...
Wolverine Quick Attach Trencher (A66408)
Wolverine Quick...
