3-Point Hitch BX25 3 point lowering question
   / BX25 3 point lowering question #11
you may have been seeing foaming, not overfilled when you pulled the dipstick. Foaming only happens when the intake tube is higher then the hydraulic oil sucking air so when it foams up, it just keeps foaming more and more, higher and higher as you use the hydraulics. On the BX, you cant stop using it as the transmission uses the same oil as with FEL/BH and 3 pt. This would account for "overflowing" when in fact its way too low. You need to check dipstick when its cold. When it has proper level of oil- it wont expand as much foaming sucking air would which is why you can see the oil on the upper or over on dipstick, but not overflowing the reservoir.
dsmiley said:
I'm guessing it will still be shy. I had the same problem with my BX25 ballast box and with 3pt forks. My solution was to purchase another adjustable side link. It comes with one to balance the lifting arms but with two you can adjust both arms down to a proper height. I think it was about $15.
Dean
Ahhhhh! The voice of experience. This may be my best option in the long run. Even though I was hopeful that adding HTS fluid would solve the problem, the more I thought about it, the more I was becoming doubtful. All other hydraulics worked. The HTS worked just fine and the snow blade went from side to side and up and down through its full range. I also thought that the lift arms went up all the way, which is a hydraulic function, but going down is just gravity. So, I couldn't see how getting air in the system, if it was sucking air, would stop the 3 point from going all the way down.
If it still has the problem when I check tomorrow, I'm ordering another adjustable side link as suggested. I have the existing one cranked pretty short to level the ballast box. I've got to solve this because I plan to get a rototiller in the Spring and this problem could cause it to not dig to full depth.
Thanks to everyone who responded to this thread, I'm going to try all suggestions. I'm sure I'll get this fixed.
   / BX25 3 point lowering question #13
Did you try jumping on the arms while the lever is down? Maybe they are binding on something,just a thought.What is the measurement from the floor to the center of the ball,that way others can tell you if theirs is the same.
   / BX25 3 point lowering question #14
I would try unhooking the lower links and make sure they go down when opened side to side all the way. If they do (and they should ) make sure now the upper arms are going all the way down. If they are and its a new machine like mine was I drilled new holes in the lower link arms. Mine was also binding up and had to get everything loose. Also make sure you can push them way about side to side and push them together as you move up and down by hand.
   / BX25 3 point lowering question #15
I might add that my left lift link was welded together wrong and was locking it up. The right one has the adjuster and could turn that was how I happened to see what the left was doing.
   / BX25 3 point lowering question #16
I have a BX25 and all my implements go down below the level of the rear tire tread. My Rototiller drag shoes go at least 4" down into loose soil. Adding a QH did not change that. I have a carry all I use for pallets of wood and it sets flat on the ground when down. Strange! A loaded ballast box should push the arms down full travel. Remember the BX 3PT has no hydraulic assist on down stroke. Might be something to do with the 3 PT lower speed valve system not releasing all the pressure. Per the BX Shop Manual trouble shooting guide and other info there the Control valve raises and lowers the 3PT. If you are doing your own work the shop manual is a must have. It has saved my Bacon several times in 500+ hrs.
Ron
   / BX25 3 point lowering question #17
I just measured the TPH on my BX2360 which is the same as the BX25.At it's lowest point the center of the hole in the ball is 9 1/2 inches off the floor.
   / BX25 3 point lowering question #18
OK, I believe I'm a contender for TBN idiot of the month, I got home from work, ran out to the tractor expecting to find an overflowing hydraulic fluid level. Nope! I couldn't even see any fluid. DUH! Then I realized that I just put the new hydraulic 60" snow blade that I bought a few weeks ago on the front of the tractor . That's why I was putting the 3 point ballast box on to help with traction and as a counter weight to the snow blade. It never dawned on me that there were 2 hydraulic cylinders and 4 hoses that were likely empty and would fill with fluid. I even allowed for that when I installed the blade by running the engine for around 5 minutes at low idle to fill the system.
Anyway, I added around 2 1/2 quarts of SUDT2 to bring fluid level up to a little bit higher than it should be. I'll move the tractor to a more level spot tomorrow, warm it up, and fine tune the fluid level. Then I'll check the 3 point hitch. I'll bet it works like it should. I'll let everyone know what happens.
Well a contender needs an opponent...right. Sign me up! I just put the same hydro plow setup on my BX so I'll be checking the fluid level as soon as I get home today. Thanks for the heads-up.
Here's the latest. I adjusted the hydraulic fluid level to what it should be. I had to remove some of the fluid that I put in yesterday using a turkey baster as it was overfilled. It is now at the correct dipstick level.
My height measurement to the center of the lower link ball is also 9 1/2 inches from the ground. So if that is correct, then all is as it should be. It still annoys me that the ballast box won't lower all the way to the ground. It is presently empty, but I did add some weight for figuring this out. If the ballast box had the recommended 300 lbs in it, having to place it up on blocks or something similar could be a bit dangerous and I couldn't remove it without having it on blocks. I have tried the 3 point drop speed control at both extremes and in the middle-----no effect on the height. I think I may take the advice of dsmiley and just put an adjustable lift rod on the left side too. They are around $35 for the whole thing, plus shipping. It wasn't something many online dealers had in stock but Coleman Equipment Inc had 1, so I just ordered it now. That should get me through until my warranties expire and I can drill another hole in each of the lower links if needed for special implements.
Maybe this will wear in a bit lower because when I first installed the 3 pt. hitch, I measured to the ground from the ball center at the lowest position and it was around 12 inches. I could slip a 4 x 4 under the ballast box. Now the BB is only about an inch off the ground at the full lowered position.
I'm going to leave everything as it is for the winter but I'll exercise the 3 point hitch every time I get on the tractor.
The picture shows the BB with the lower links at their lowest when this shot was taken. See how much space is between the bottom of the box and the ground, around 4 inches. It is now only about an inch, so maybe it just needs broken in a bit more.
Thanks to everyone for the suggestions and advice. If this improves at some point, I'll post about it. I'll let you know how the adjustable lift rod works out too.
Paul
   / BX25 3 point lowering question #20
Just curious if your BB is made for the BX25 as Kubota makes different models of them.If so is it possible to relocate the pins higher on the box? It makes me wonder what Kubota is thinking if they designed their products this way.I remember being frustrated with the TPH on my BX25,when I had it,in that it wouldn't lower enough to unhook my chipper without putting blocks under it.
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
VOLVO ECR25...
