Buying Advice Bx24
ced
illinois
john deere 4310
Going to look at a bx24 tomorrow. It has 1500 hours. Of course the loader and backhoe, but also includes a 60"mmm and 3 point carry all. He is at $9000. Anything as far as problem areas I need to lookout for........
Check the hydraulics cooling fan underneath. Look for cracks on the at the joint of the fender and floor/see if they put in the kit to fix the problem. Love my BX24, good luck.
Take Care,
Doug in SW IA
The bracket for the air cleaner is prone to failure because the engine vibrates quite a bit at low rpm. Check for cracks. Lots of owners bought or made their own reinforcements, which solves the problem.
Try to find out if engine and hydraulic fluid has been changed regularly... keeping them clean and fresh is important. If the service has been done, 1,500 hours is nothing to worry about; if it was never done, keep shopping.
/ Bx24
Thanks for the advice. I had to pass on it. It was spray painted on the loader and backhoe. I hate when I see that! Also the air filter was plugged almost solid. Hard to believe it even ran. Had the hood bonnet cracked and broken in several spots as well.
/ Bx24 #5
Sounds like it has had a rough life. Almost better that way, makes your decision easier. Happy hunting.
Take care,
Doug in SW IA
/ Bx24 #6
ced, I looked at an old Ford tractor/backhoe yesterday that would have made that BX24 look like a showroom new model. When people are too lazy to clean an air filter before showing a tractor, or they use spray paint to cover up problems but are too lazy to even try to do a decent job with the paint, it tells you something about their maintenance habits.
/ Bx24 #7
Sounds like a good decision. They are great little tractors, but like anything else, they need to be maintained. Best of luck in your search.
/ Bx24 #8
There are good ones out there but as you've found, they can be mortally abused. On the other side of the coin (the mint ones) never make it to advertising, when someone says the word, the phone starts ringing. Nice ones don't last long and sometimes at insane prices.
2023 Stearling Trailer (A60352)
2023 Stearling...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
3ft. Wooden Cowboy Statue (A61569)
3ft. Wooden Cowboy...
(INOP) 2004 PETERBILT 378 T/A DAY CAB ROAD TRACTOR (A62130)
(INOP) 2004...
2011 John Deere 1770NT Planter (A63109)
2011 John Deere...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
