radioman
Super Member
able to loosen the floor boards, but struggling with the removal of the Rear Fender. took ROPS off, then there is the handle on the left ... a nut that needs a serious socket wrench extension to get any turn on it. Anyone ever remove this? know what size extension on the socket to use? Anyone ever take off that rear fender? after this there is the PTO dial (if thats what its called) and the belly mount adjusting dial. from the looks of it the large round handles of the dials need to be removed -how the heck do i take this off? My plan was to do all this breakdown tonight but got stuck on the fender.
So far as the wireharness goes - this is a big ole strand of wires with some real tight corners. they must make small hands in Georgia and Japan. this is somewhat reverse engineering to remove the old, add in the new, but man its tight.
please help me on the know how to remove the rear fender...
I haven't removed th fender yet- but i do know the knobs just pull straight off, otheer tbn'er had hard time too. (its a 3 pt draft control to control down rate speed not pto dail)
as for handle on left, are you referring to the holding handle ? its 14mm socket.
good luck.
