BX24 Wire Harness
/ BX24 Wire Harness #1
gwdemos
South Kingstown, RI
well the mice got in, and my dog decided to rip off the cover under the dash the metal screen, the bracket and ripped all the wires out from under the dash. I lost all dash display and was told that the wire harness is available ONLY as one complete strand (i.e, i can't just replace the dash wires to the fuse box)
Question: Has anyone done a complete wire harness replacement on the BX24? Were you able to snake everything or did it require a removal of the fender and floor board? Please let me know what to expect as i get into this job.
Trying to determine if this is a DIY job or a task for a service tech.
/ BX24 Wire Harness #2
I would repair the harness make sure you use the same size wire.
If its beyond repair you could buy a new one install it were needed and tie in the 6 or 8 wires that go back to rear of tractor.
The ones under the hood shouldn't be an issue to get to.
I would lay it in parallel with the old one and disconnect the old plug the new one in should be relativity easy
put some dryer sheets in the dash area and under the hood change them weekly they seem to keep mice away.
/ BX24 Wire Harness #3
What are "dryer sheets" ? I did find a mouse nest in my BX24 but it appears that I caught the problem in the nick of time. If someone steers me on the dryer sheets topic, I would appreciate it.
/ BX24 Wire Harness #4
dryer sheets are those funny white fabric your wife uses in the dryer to prevent static in clothes. makes it smell good too. Bounce is one brand name.
/ BX24 Wire Harness
will try the dryer sheet. good tip.
spoke to 2 other local Kubota dealers, neither have done the complete harness replacement; but both suggest that it means the removal of the floor board & fender. hope i have the right tools.
/ BX24 Wire Harness #6
Good luck with your project...Mice have created a lot of conversation on here.
Don
/ BX24 Wire Harness #7
I took the floorboard off mine and all you need is standard tools. If you have both metric and standard socket and wrenches, you will be just fine. I haven't taken the fenders off yet, but you need to remove the ROPS first to remove the fender. have fun and take your time. It will take 2-4 hours just to take it apart I think. If you replace the whole harness, It would be great if you can post pictures of the harness being replaced.Who knows- sometime down the road I might have same issue as you.
/ BX24 Wire Harness
able to loosen the floor boards, but struggling with the removal of the Rear Fender. took ROPS off, then there is the handle on the left ... a nut that needs a serious socket wrench extension to get any turn on it. Anyone ever remove this? know what size extension on the socket to use? Anyone ever take off that rear fender? after this there is the PTO dial (if thats what its called) and the belly mount adjusting dial. from the looks of it the large round handles of the dials need to be removed -how the heck do i take this off? My plan was to do all this breakdown tonight but got stuck on the fender.
So far as the wireharness goes - this is a big ole strand of wires with some real tight corners. they must make small hands in Georgia and Japan. this is somewhat reverse engineering to remove the old, add in the new, but man its tight.
please help me on the know how to remove the rear fender...
/ BX24 Wire Harness #9
Did you buy the Kubota insurance policy for while you're making payments? I'm thinking that this would be a valid claim and let the service techs do the cussing....
/ BX24 Wire Harness
yeah, let that policy expire a few years back. they'd cover Acts of God, not sure about Acts of Dog though ;). have a couple pics i'll post of the before. if you look under the dash and follow the instrument cluster it goes from there to the fuse box...crappy wires as thin as dental floss and they were shredded in all the worst places - soldering helped to some extent but couldnt get them all and replacing wires was not an option as some were shredded right at the gang plug. still wondering about this fender removal
/ BX24 Wire Harness #11
I haven't removed th fender yet- but i do know the knobs just pull straight off, otheer tbn'er had hard time too. (its a 3 pt draft control to control down rate speed not pto dail)
as for handle on left, are you referring to the holding handle ? its 14mm socket.
good luck.
/ BX24 Wire Harness
yeah, saw a post on removing the dial handles, I will put the heat gun to it and see if it will budge. yes, the handle to the left of the seat, i think it will require a 6" socket ext no room to turn otherwise.
next problem i'm wonder about: FUEL PUMP. messicks says a 30 sec turn of the key will purge air in the line. i was able to get her running, but when going UPHILL she bogged down and died. perhaps just the filter, which i just changed, question is: if the FUEL PUMP was dead, would the engine get any fuel whatsoever? in other words, if the FUEL PUMP were dead that means it would simply not start - correct?
/ BX24 Wire Harness
Here's an update, this is a sizable job. Floor and Fender Must come off, seat must com off, of course the full ROPS assembly including brace that holds fuel tank (one under ROPS that 19mm bolts to the subframe) and the forked bracket at the front of the tank.
starting at the headlights, pretty straight forward, turning up under the dash was a bear. snake the hazard/light switch gang wires and plugs up over the dash frame, and very tricky plugging in the gauges, more difficult plugging in the ignition (couldnt figure out how to remove the ignition.)
Then time to remove the rear fender -needless to say alot of cleaning thereafter, compressed air helps & a good shop vac, particularly blasting debris out from under the fuel tank and every other hidden corner.
there is a 12 v plug that is tough, and the safety switch adjacent (far under right corner of seat) must be removed to plug/unplug. prop up the fuel tank, bring all rear wires under the tank (rear lights etc).
doing this once is all i'd wish on anyone, although a second time around would go quicker. this is a total breakdown but i've learned a good deal about the tractor in the process. not done yet, moment of truth hopefully later today.
2013 Mercedes Benz GLK SUV (A64557)
2013 Mercedes Benz...
2013 International DuraStar 4300 S/A Dump Truck (A64556)
2013 International...
2004 Harmon Steel Barrel Asphalt T/A Tanker Trailer (A64194)
2004 Harmon Steel...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
HARDEE 300 GALLON PULL TYPE SPRAYER (A64278)
HARDEE 300 GALLON...
