BX24 Trans slipping
/ BX24 Trans slipping #2
Fluid sufficient and screen clean if Hydro?
Also... is the Hydro Selector in Low Range...
Some have had problems because the Hydro was in High and the tractor basically would not move on inclines.
/ BX24 Trans slipping #3
All BX's were HST. They have proven very realiable but I can recall at least one person on here having to fix one.
/ BX24 Trans slipping #4
are your tires fluid filled? i would mark your tires and rim and drive around a bit. i bet its slipping at the rim. if rim seems ok,, did you check the hst fluid level cold?
/ BX24 Trans slipping #6
More details on the symptoms would be helpful. Some "slipping" feeling has been the pedal linkage coming loose.
Doug in SW IA
