BX24 Starting Problem
/ BX24 Starting Problem #1
bobfuss
Kubota BX24
I just got this used tractor and I do not have a manual for it. I have ordered a manual.
I have run the tractor several times, with no problem. Today I started it and drove it around to a spot to pick up some stuff. When I went to get off, the engine quit. I am guessing I did not have some lever set correctly, or there is an interlock switch on the seat. However when I get back on and sit down, the tractor will not crank.
Any help?
Thanks,
Bob
/ BX24 Starting Problem #2
To the left of your seat is the PTO lever. I bet that you touched it with your hip when you got off the tractor, I do sometimes. Move the lever down and back up and try starting your tractor again.
If that doesn't do it, move your hydro pedal and find neutral and try restarting.
It was the PTO lever, thanks.
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2022 EZ-GO ELITE...
2017 Chevrolet Silverado 1500 Pickup Truck (A64194)
2017 Chevrolet...
JOHN DEERE QUICK ATTACH PALLET FORKS (A64278)
JOHN DEERE QUICK...
2013 Vermeer Vac-Tron LP855SDT T/A Vacuum Trailer (A64194)
2013 Vermeer...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
