Snow BX24 Snowblower - not working - need help/advice
   / BX24 Snowblower - not working - need help/advice #1
beaubear
NEED HELP/ADVICE - Ran tractor this morning in 10 inch snow on paved driveway. Blower stopped throwing snow. All three shear pins intact and all augers/impellers will turn manually but not under power. Chain is tight and all shafts turning. Dealer can not pick up machine for several days. Any ideas?
   / BX24 Snowblower - not working - need help/advice #2
Look for a broken shear bolt and or missing key on the drive shaft coupling
Parts 19 and 21 hold the drive yoke 6 to the shaft
   / BX24 Snowblower - not working - need help/advice #3
Can you see both ends of the sheer pins? I've seen one end of a broken pin "stick" so it looks like it's still there from one end.
With the tractor off, and the PTO on (locked so it can't turn) , can you turn parts of the blower to see what turns and what doesn't . Your problem is probably at the junction of the two. Hopefully a sheer pin. Good luck.
   / BX24 Snowblower - not working - need help/advice #5
I just took the chain guard off of mine to lubricate it after 6 hrs. of use and both set screws came out of the small sprocket , I was able to find them laying under the sprocket area . I put them back in with some locktite , the key ( no. 13 ) did stay in place on mine .
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
UNUSED SDLANCH PORTABLE WOOD CHIPPER (A57193)
UNUSED SDLANCH...
2016 BOMAG BW 177D5 SMOOTH DRUM ROLLER (A52707)
2016 BOMAG BW...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
