Snow BX24 Snowblower - not working - need help/advice
   / BX24 Snowblower - not working - need help/advice #1
beaubear
NEED HELP/ADVICE - Ran tractor this morning in 10 inch snow on paved driveway. Blower stopped throwing snow. All three shear pins intact and all augers/impellers will turn manually but not under power. Chain is tight and all shafts turning. Dealer can not pick up machine for several days. Any ideas?
   / BX24 Snowblower - not working - need help/advice #2
Look for a broken shear bolt and or missing key on the drive shaft coupling
Parts 19 and 21 hold the drive yoke 6 to the shaft
   / BX24 Snowblower - not working - need help/advice #3
Can you see both ends of the sheer pins? I've seen one end of a broken pin "stick" so it looks like it's still there from one end.
With the tractor off, and the PTO on (locked so it can't turn) , can you turn parts of the blower to see what turns and what doesn't . Your problem is probably at the junction of the two. Hopefully a sheer pin. Good luck.
   / BX24 Snowblower - not working - need help/advice #5
I just took the chain guard off of mine to lubricate it after 6 hrs. of use and both set screws came out of the small sprocket , I was able to find them laying under the sprocket area . I put them back in with some locktite , the key ( no. 13 ) did stay in place on mine .
2020 Bobcat T550 Compact Track Loader Skid Steer (A55851)
2020 Bobcat T550...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2007 Jeep Liberty SUV (A55853)
2007 Jeep Liberty...
2007 Chevrolet Silverado 1500 (A55973)
2007 Chevrolet...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2025 IRET 13 Utility Electric Tricycle (A55853)
2025 IRET 13...
