BX24 rear of HST leaking
   / BX24 rear of HST leaking #1
fishpick
Platinum Member
The part of NY with high taxes
L4760 & BX24
Has anyone had a leak back there? More relevant - is there a common thing on the back of the HST that leaks on a BX24?
I have a BX24 that I have noticed the whole back of the HST case has accumulated that "dirt that's there because of a leak" kind of look. For the last couple of years I assumed it was most likely from the little red relief valve at the top just blowing off... but this year I had the tractor in the barn to prep the deck and saw a drop of HST fluid on the floor. Clearly more than a blowoff.
I cleaned everything up and started waiting and hunting for a leak. It almost seems like MAYBE it's the RTV gasket around the square plate on the back that's leaking.
And no - it's not the seal around the PTO.
   / BX24 rear of HST leaking #2
How about the seals on the axle shafts? That is a common problem as they get older/higher hours.
   / BX24 rear of HST leaking #3
If it is just a drop, 2" diameter or smaller, you may wait a long time as a small amount of oil will create a mess larger than what it actually is. In that case, it could be a drip from an accumulation of blowby or just a very small leak.
nope - it's more central. I'm pretty sure it's the RTV around the back.
I think it's way more work to fix than its currently leaking :) But I will keep my eye on it - I'm fairly certain it's more than the blowoff at this point.
   / BX24 rear of HST leaking #5
If you have the back hoe connections, take a look at them. I thought I had a leak back there but I think it was just a connection that hadn't seated.
Doug in SW IA
2025 Spirit Electric Scooter (A55853)
2025 Spirit...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2007 Chevrolet Uplander LS Van (A55853)
2007 Chevrolet...
2020 Kubota SVL75-2 (A53317)
2020 Kubota...
