BX24 PTO tiller
   / BX24 PTO tiller #1
kdm0811
Lynchburg, Virginia
BX24 and RTV500
I would like some advise in selecting a PTO driven tiller for my BX24. I have red clay with a fairly high percentage of rocks. Is a 48" unit too much? Does anybody have one of these that is "in their way"? Central Virginia.
   / BX24 PTO tiller #3
I have a bush hog tiller and it just under the width of my BX24 tires. I have used it in the hayfeild, clay like soil, good soil for garden and areas where wild vines grow across ground and tiller goes though it just fine. I think its a perfetly match unit so i wouldnt use anything more then 48" and make sure you have a slip clutch installed too.
   / BX24 PTO tiller #4
Radioman,
From what I've read on this site (which incidently, thanks to you guys, is a God send to me) you might consider a middlebuster or sub-soiler to cut up the ground a little before you till.
Or maybe even better maybe, might be a tool bar (very beefy) that you can attach various size soil busting blades, sub-soilers etc to. I saw a great set up that was very versital with various kinds of tools. More money, but definitally a useful set up that you can keep adding stuff to...thereby, further feeding the addiction.
Good luck. paul
   / BX24 PTO tiller #5
Would go with a 48''
   / BX24 PTO tiller #6
Sorry kdm0811, I sent a reply to your post to "radioman"! The good news is radioman won't get upset if you read it...I don't think anyway.
You also mentioned rocks. That's why a preliminary pass with a middlebuster etc. might help save beating up the tiller. A lot of times you can kick out the big ones before the tiller get's it.
Pretty much everyone agrees that a 48" tiller is a good way to go for that tractor. I have a BX2350 and have been looking at tillers myself.
Paul
   / BX24 PTO tiller #7
Paul
:p just laughing santacruzer
   / BX24 PTO tiller #8
i was planning on a 48" but a pretty good deal on a 54" monster came my way so that's what i ended up with. it is heavy duty and heavy but the bx handles it pretty well and i baby it with all that weight on the back. i usually run at half throttle or less and inch along when breaking new ground.
i will say this as i have learned from other posts on this site. it is nice to have a tiller that can cover both wheel tracks and you can always remove the outside tines on an oversized unit. you can't really add tines to a tiller that is too small.
the one i have is also reversible and off-settable but it's quite a chore and i haven't had time to mess with it yet. maybe someday i'll tackle it and post up the results.
slip clutch definitely a good investment. don't go over 750 lbs on the 3 pt. of a bx24. it gets a little iffy. ;-)
amp
   / BX24 PTO tiller #9
Check in your owners manual.
I might not be correct but I believe they only recomend a 42" for a BX24, which is what I have.
Also get a slip clutch model.
   / BX24 PTO tiller #10
The BXs will handle a 48 incher - Piece of cake.
You don't want a 42 inch cause it won't cover booth wheel tracks.
I see more 48 inchers than 42 inchers around this site.
JLG 1255 Telehandler (A52748)
JLG 1255...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
