BX24 PTO tiller
   / BX24 PTO tiller #1
kdm0811
Lynchburg, Virginia
BX24 and RTV500
I would like some advise in selecting a PTO driven tiller for my BX24. I have red clay with a fairly high percentage of rocks. Is a 48" unit too much? Does anybody have one of these that is "in their way"? Central Virginia.
   / BX24 PTO tiller #3
I have a bush hog tiller and it just under the width of my BX24 tires. I have used it in the hayfeild, clay like soil, good soil for garden and areas where wild vines grow across ground and tiller goes though it just fine. I think its a perfetly match unit so i wouldnt use anything more then 48" and make sure you have a slip clutch installed too.
   / BX24 PTO tiller #4
Radioman,
From what I've read on this site (which incidently, thanks to you guys, is a God send to me) you might consider a middlebuster or sub-soiler to cut up the ground a little before you till.
Or maybe even better maybe, might be a tool bar (very beefy) that you can attach various size soil busting blades, sub-soilers etc to. I saw a great set up that was very versital with various kinds of tools. More money, but definitally a useful set up that you can keep adding stuff to...thereby, further feeding the addiction.
Good luck. paul
   / BX24 PTO tiller #5
Would go with a 48''
   / BX24 PTO tiller #6
Sorry kdm0811, I sent a reply to your post to "radioman"! The good news is radioman won't get upset if you read it...I don't think anyway.
You also mentioned rocks. That's why a preliminary pass with a middlebuster etc. might help save beating up the tiller. A lot of times you can kick out the big ones before the tiller get's it.
Pretty much everyone agrees that a 48" tiller is a good way to go for that tractor. I have a BX2350 and have been looking at tillers myself.
Paul
   / BX24 PTO tiller #7
Paul
:p just laughing santacruzer
   / BX24 PTO tiller #8
i was planning on a 48" but a pretty good deal on a 54" monster came my way so that's what i ended up with. it is heavy duty and heavy but the bx handles it pretty well and i baby it with all that weight on the back. i usually run at half throttle or less and inch along when breaking new ground.
i will say this as i have learned from other posts on this site. it is nice to have a tiller that can cover both wheel tracks and you can always remove the outside tines on an oversized unit. you can't really add tines to a tiller that is too small.
the one i have is also reversible and off-settable but it's quite a chore and i haven't had time to mess with it yet. maybe someday i'll tackle it and post up the results.
slip clutch definitely a good investment. don't go over 750 lbs on the 3 pt. of a bx24. it gets a little iffy. ;-)
amp
   / BX24 PTO tiller #9
Check in your owners manual.
I might not be correct but I believe they only recomend a 42" for a BX24, which is what I have.
Also get a slip clutch model.
   / BX24 PTO tiller #10
The BXs will handle a 48 incher - Piece of cake.
You don't want a 42 inch cause it won't cover booth wheel tracks.
I see more 48 inchers than 42 inchers around this site.
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
Bush Hog (A50322)
Bush Hog (A50322)
2000 Trinity Built Trailer (A50514)
2000 Trinity Built...
2008 Club Car DS 48V Electric Golf Cart (A51568)
2008 Club Car DS...
