BX24 possible to fit a 48" mowing deck?
   / BX24 possible to fit a 48" mowing deck? #21
A quick check at Kubota.com shows the "new" 48" MMM as RCK48-18BX. It's designed to fit the shorter wheelbase (wb) BX1850 only. It is not listed as an option for the BX2350 nor BX24.
I don't know if the wb of the BX1850 is the same as the previous BX15XX's or if the mounting tabs are the same but the new/older model 48" MMM's do have different part #'s.
   / BX24 possible to fit a 48" mowing deck? #22
You are correct, and the wheel base of the BX1500/1830 are the same at 52.8" The decks are simular but there are some differences in the decks. In particular the mounting points.
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
Toro 3100D (A50324)
Toro 3100D (A50324)
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
