bruere
- Joined
- Jan 19, 2012
- Messages
- 25
- Location
- Yea Victoria Australia
- Tractor
- Kubota BX25, Husqvarna LTH 2142DR ride
cubowner u did mention ur coolant leak was related to full throttle . At full or high throttle the cooling fan is at high speed drawing air through rad over engine and out sides and front of bonnet . possible leak from radiator or another area spraying coolant around . some leaks only appear when parts r cold and fully contracted i.e water pump seal rad hose at clamp seal point and gaskets . U can always see external leaks once located . use torch and magnifying glass , be a detective , deduce , . most leaks end up being simple . make sure both hose clamps replaced . let us know how it goes. good luck
