BX24 hydro fluid
/ BX24 hydro fluid #1
ejnichol
Is the hydro fluid used in a late model 2006/2007 bx24 the UDT named product. Do you use standard or Super?
thanks
/ BX24 hydro fluid #2
The manual specifies Kubota Super UDT. When my tractor was delivered, Mr. Messick said, "Oil, whatever, coolant, any brand, whatever, but for the HST, we strongly recommend that you use the Kubota branded fluid that they specify." I figure it's worth the cost even if it only might matter.
/ BX24 hydro fluid
thanks. My owners manual is out of town I'm intown.
/ BX24 hydro fluid #4
Can you mix Super and regular UDT???
In other words say my dealer did my 50 hour tune up with reg UDT, can I top off with Super UDT?
/ BX24 hydro fluid #5
The fluids are compatable.
/ BX24 hydro fluid #6
I was a little disappointed today when I called my dealer to get a price on Super UDT. They don't have it, they only use UDT.
But, but the manual calls for Super UDT for the BX24, I said.....hmmm they said, never use it :(
I think I know where NOT to get my tractor worked on under warranty. Funny part is the salesman stressed it was a good idea to use only Kubota products during the warranty period to avoid any question if there is a problem- then his own service department uses the wrong fluid:cool:
/ BX24 hydro fluid #7
I put regular UDT in my BX24 at the 50 hour mark. I tried to buy the Super but the dealer in Oregon (great dealer highly rated but not mine, I was on a road trip) talked me out of it. They said that the super stuff is colder climates mainly. They said the main difference was that it would take longer to warm up in cold weather and that if I wasn't going to be using it at 20 degrees or so then I shouldn't need the super stuff.
/ BX24 hydro fluid #8
All I have to go on is Kubota's manual which plainly shows on page 64 KUBOTA SUPER UDT FLUID :confused:
But then on page 65 it says "We recommend the use of KUBOTA SUPER UDT fluid for optimum protection and performance"
So is it recommended or required?
/ BX24 hydro fluid #9
I also firmly believe in going with what the manufacturer recommends 99% of the time when it's something I'm not more educated in (which is typically the case). I wish this weren't the case though, since 5 gallons of hydro fluid at Sam's Club is like $27, and the 5 gallons of Super UDT I picked up was over $80! But, the extra $50+ in a $16,000 tractor is worth it for peace of mind.
/ BX24 hydro fluid #10
I sort of figure the same thing about buying their fluid for the HST. It seems to be overpriced but then again a repair or replacement of a failed HST is probably even more ridiculously expensive. Now engine oil is another matter and I'll change it much more often than the HST fluid and I know I can go aftermarket and get a quality product there, not so sure about the SUDT or UDT:confused:
I don't know if the HST is comparable to the auto trans in cars/trucks or not as far as reliability, ie most cars/trucks fail the transmission long before the motor gives up....always has puzzled me why many engines far outlast the transmission they drive....something doesn't seem right there in the engineering.
/ BX24 hydro fluid #11
I hate you... :D
I run Super... obviously... because of the reason I hate Singlecoil... it gets cold here.
I'm of the logic of using Kubota fluids until out of warranty time... then go hog wild with whatever fluid you want on your dipstick.
/ BX24 hydro fluid #12
I'm really trying to run Super UDT, as I said my dealer only uses regular UDT. So today I stopped by another Kubota dealer about 30 miles away to buy some SUDT and they don't use either! They use New Holland fluid only:cool:
I asked the parts guy if that ever caused a warranty issue and he said no....
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2022 EZ-GO ELITE...
LOOK! (A65640)
LOOK! (A65640)
John Deere 2032R Loader Tractor (A66285)
John Deere 2032R...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
Massey Ferguson 285 Loader Tractor (A66285)
Massey Ferguson...
