BX24 Differential lock linkage part number or diagram
   / BX24 Differential lock linkage part number or diagram #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
Hi all,
I noticed today that my differential lock pedal on my BX24 felt as though it was attached to nothing but a spring. So, I popped off the wheel to take a look, and it appears that some linkage is missing. Would anyone happen to have a parts diagram or parts number of the missing component(s) here? I drew some arrows at what I'm assuming are the two connection points for what I assume is just a simple rod. (Attached picture)
Thanks
Beautiful. Thank you OrangeRidge!
   / BX24 Differential lock linkage part number or diagram #4
Hopefully, you bought the tractor new and it was just a part failure.
If it was previously owned, this would be an easy way for the former owner to hide a problem with the diff lock by just disconnecting it!!
   / BX24 Differential lock linkage part number or diagram #5
Mine fell off. Found it on ground where I had been working. Dealer put it back on when it was in there for some work. Yours probably just fell off. Look on the ground where you been working it. You can get the schematic from messicks parts dept.
Luckily, it was new, and I do know the lock was working prior to this rod falling off. Thanks.
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
2018 Ford F-350 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
