BX24 Differential lock linkage part number or diagram
   / BX24 Differential lock linkage part number or diagram #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
Hi all,
I noticed today that my differential lock pedal on my BX24 felt as though it was attached to nothing but a spring. So, I popped off the wheel to take a look, and it appears that some linkage is missing. Would anyone happen to have a parts diagram or parts number of the missing component(s) here? I drew some arrows at what I'm assuming are the two connection points for what I assume is just a simple rod. (Attached picture)
Thanks
Beautiful. Thank you OrangeRidge!
   / BX24 Differential lock linkage part number or diagram #4
Hopefully, you bought the tractor new and it was just a part failure.
If it was previously owned, this would be an easy way for the former owner to hide a problem with the diff lock by just disconnecting it!!
   / BX24 Differential lock linkage part number or diagram #5
Mine fell off. Found it on ground where I had been working. Dealer put it back on when it was in there for some work. Yours probably just fell off. Look on the ground where you been working it. You can get the schematic from messicks parts dept.
Luckily, it was new, and I do know the lock was working prior to this rod falling off. Thanks.
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
