BX24 Differential lock linkage part number or diagram
   / BX24 Differential lock linkage part number or diagram #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
Hi all,
I noticed today that my differential lock pedal on my BX24 felt as though it was attached to nothing but a spring. So, I popped off the wheel to take a look, and it appears that some linkage is missing. Would anyone happen to have a parts diagram or parts number of the missing component(s) here? I drew some arrows at what I'm assuming are the two connection points for what I assume is just a simple rod. (Attached picture)
Beautiful. Thank you OrangeRidge!
   / BX24 Differential lock linkage part number or diagram #4
Hopefully, you bought the tractor new and it was just a part failure.
If it was previously owned, this would be an easy way for the former owner to hide a problem with the diff lock by just disconnecting it!!
   / BX24 Differential lock linkage part number or diagram #5
Mine fell off. Found it on ground where I had been working. Dealer put it back on when it was in there for some work. Yours probably just fell off. Look on the ground where you been working it. You can get the schematic from messicks parts dept.
Luckily, it was new, and I do know the lock was working prior to this rod falling off. Thanks.
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A49461)
2011 Kenworth T300...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
RIGID TOOLBOX (A50854)
