BX24-BX25
   / BX24-BX25 #4
it looks the same and works the same.
BUT !
BX24
pros
has plastic hood and fenders. won't rust!
3 point hitch included
cons
jerky transmission ( I know I have one)
BX25
pro metal hood and fender. wont crack! and everything good from BX24.
con no 3 point hitch, you HAVE to add on.
   / BX24-BX25 #5
In addition to the above, the hydraulics work at idle and less noisy hydrostat on the later 25 series. Definatly test the hydraulics @ idle and higher, and drive both, switching between forward and reverse. This way you absolutely know what you are getting and won't have any complaints. Personally I would like the 25 better but depending on the actual units that you are looking at and the price point of the deal you might be also happy with the 24.
   / BX24-BX25 #7
How is the transmission more forgiving???
Craig
Certain BX models and some B models of the recent past had HST's that were rather abrupt to stop, shall we say. The current models roll a bit to a stop. Most, it seems, prefer the rolling stop rather than the abrupt stop.
   / BX24-BX25 #8
If I have the loader and the hoe attached to my 24, and in hi range in reverse, lifting my foot all the way off the pedal can cause the front wheels to come off the ground. Kinda fun:D. It's not bad in low range though. I'm ok with it.
   / BX24-BX25 #10
Its funny everyone say about the plastic fenders. My BX24 seems to have steel fenders not sure about the hood. I got mine just as the BX25's were coming out. Still got the abrupt tranny thou. Byt its not so bad once you learn to use it
2020 Exmark ECX180 21in Push Mower (A52377)
2020 Exmark ECX180...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
2014 Peterbilt National Crane Series 900A 26 Ton Tri-Axle Crane Truck (A52377)
2014 Peterbilt...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
