Bx24 brake Problem/question
   / Bx24 brake Problem/question #1
roma3112
metro boston
simplicity 3112h
Today after a hard days use pushing snow around the yard I went to put the machine away, well being in low gear from pushing i went to switch into hi. Being on a hill i went to apply the brake to safely change gears when much to my dismay the pedal went to the floor ???????? Long story short i went looking on here for a possible cause. I read this post and I too Hardly Ever use the brake except for when its on a trailer. I have no hills in my yard when i mow. I checked the linkage and Nothing had popped off. The machine had been to the dealer recently to have some loader lines replaced and to adjust the hydro because of a nasty creeping problem; which by the way is better but not gone.
I backed into the garage jacked the rear end up applied the brake and went to spin the rear wheels and zero resistance. I then tryied to adjust the turnbuckle on the right side of the machine. I got some of the free play out of the pedal but again zero resistance when the rear end is in the air and i spin the back tires by hand. Fearing that there was some sort of internal problem I put the turnbuckle back to where it was and let it down, and figured that I would call the dealer on mon When traveling back to the shed with the BX i decided to stop on a small hill and slide the trans into neutral to test the brakes again.
Not expecting anything I let the machine start to go (with my hand on the loader control to stop the thing if i had to I found out that the brakes held????? Is there something I am missing here I am ignorant to this type of braking system but Why do the brakes work when the machine is on the ground but not when the rear end is in the air??
This still does not answer the question about the brake pedal having soo much free play?? Nearest I can figure is that for some reason mabee the dealer adjusted it when trying to fix the creeping problem?? I guess I am not sure if i have a problem now or not I can adjust the turnbuckle back to an acceptable amount of free play but mabee it is just my ignorance of how these brakes operate. If anybody can educate me please chime in
thanks
john
roma3112 is offline Report Post Edit/Delete Message
   / Bx24 brake Problem/question #2
The brake is on the drive line not on the wheels, both wheels need to be on the ground for the brake to work.
Cory
both the factory warranty and the warranty thru the financing are in effect. I was abel to adjust that turnbuckle almost to the end of its adjustment and I got a normal pedal back. I fear #1 that if the brake was draging that I must have ate away at alot of its life, and basically thru normal use what I have now for brakes would be something I should be left with years in the future. I never use the brakes, i have no hills and no need to. Its only because I was shifting into neutral on a hill that I found the problem, kind of like your leak. So by coincidence i found the problem :(
My dealer is Not that helpful and is over an hour trip one way, so to borrow a truck/trailer get it there and back is a PITA. I am wondering if they may have touched the brake adjustment when they tryied to fix the creeping problem ???? As far as what is left on that turnbuckle I have about a half inch of threads left to go. I am not sure what to do for sure I am going to call the dealer, but if he jams it to me and says it was neglegence I dont want to be stuck with the bill. The other thing I fear is that all he will do is tighten the turnbuckle on the pedal linkage and call it "normal" which I know os a crock of S*&t; and not inspect the internals for overhearting/damage :(
When adjusted out the brakes DO work and will lock the machine up tight. Its just that there is little if any adjustment to the linkage.
   / Bx24 brake Problem/question #5
The creeping problem is adjusted by springs in front in underneath floor of hydro waaaay up on right hand side. There a lock nut for hydro pedal you can adjust tension for and its doesnt do a thing for brakes. SO where is this leak ? the other link you posted to was for a front axel, dont see how its related to brakes. (take it easy on me, haven't had full cup of coffee yet ;))
RADIOMAN
I hear ya about the coffee :( I have no leak corey who had a similar post/problem had a leak which wound up causing him to find out about a brake problem VV similar to mine.
My machine just had a problem with creeping and since the last time to the dealer (1.5 months ago) I just yesterday noticed that the brake pedal had nearly NO bite it would go to the floorboard. I adjusted the linkage all the way (nearly) to the end of what it will let you adjust and now the brake pedal has about an inch or so of travel then it grabs and works well. However I dont think that this is normal to have to adjust the linkage all the way down to the end to get a good pedal. And why all of a suddon would it do this.
   / Bx24 brake Problem/question #7
not sure- I havent had issue with my brakes yet since new and its over 500 hrs i think now. perhaps the pads disintegrated ? Only way to tell is take a look. wish I had wsm to check that.
I have the WSM and it does not look like an easy job at all!! Has anybody here replaced the brake linings on a bx before??
   / Bx24 brake Problem/question #10
When they did mine, it was a week long job for them. They had the entire rear end of the tractor torn down when I went in to check out the brakes. They were worn completely down, and the metal had blued from the heat. I think that's what you're going to find is going on with yours. I would get it in before your warrantee is up.
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A52128)
2023 MAXXD TDX...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
