BX24 blowing hydraulic filters
   / BX24 blowing hydraulic filters #31
Suki, I have just tried to send you the BX23S WSM via Personnal Message (PM). Let me know. It has full info. Much better than more recent manuals.
Also found in the WSM more hydraulic diagrams. One identifies (#3) as a relief valve that may also affect your filter pressures. Worth checking, but read the WSM if it arrives.
Nice to see someone willing to do their own diagnostic work these days instead of dealer.
rScotty
BX23S hydrauic Circuit another view HST relief (#3).jpgBX23S Power Steering.jpg
   / BX24 blowing hydraulic filters #32
rScotty
View attachment 3613831View attachment 3613832
If you figure out how to get the WSM, setting the HST reliefs & charge pressure is on pg. 257.
The PTO works on 150 psi, but the HST reliefs at 3000 psi. That is enough pressure to be deadly and cut a foot off.
Please be careful. 10 seconds max on the relief. The WSM implies that those HST relief valve had a nut that coud back off, .
Scotty, thank you so much for your info. The last filter was blown apart inside. We ordered them a Kubota dealer and they were the hydraulic ones.
rScotty
thank you so much. We did the Pressure test with gauge on loader and pressure was at 1250 or just a bit higher and it blew the filter. Does this mean it is happening between filter and loader? Line flattened, kinked?
It blew the filter inside all apart.
Per schematic attached by rscotty the filter is after the PTO relief and before the HST charge relief. If this is correct the charge relief would be the only relief that would affect the filter or an obstruction between the filter and charge relief.
Other potential concern would be if the priority flow valve is somehow allowing more flow to steering- charge circuit which may increase charge pressure. I recall some posts in the past about priority valves failing but do not recall what the failure mode was.
Suki,
I do not recall - remember how to check the charge pressure but 99% positive that it explains how in the work shop manual
Thank you for the info. Gonna print it out. So frustrating. We tested pressure according to manual and the loader didn't get to 1300psi and the filter blew...it destroyed the inside of the filter.
Do you think this translates to a BX24D?
   / BX24 blowing hydraulic filters #37
Could you post a picture or pictures of where this filter mounts Just so that we are all on the same page.
Is this filter in the backhoe loop vs what manual shows as charge pump filter. Curious if backhoe had a filter or is this something added on by an unknown person.
Blowing innards on an element seems very unusual so makes a person wonder what are we missing.
   / BX24 blowing hydraulic filters #38
Do you know what the spec is for pressure at the loader? That sounds low but it could be that’s spec for your tractor.
   / BX24 blowing hydraulic filters #39
The OP didn't say what the loader was doing when pressure was measured. That pressure should vary from (0) psi to full relief pressure (2900 psi) depending on what they are trying to lift . 1250 psi is about right for just raising and lowering an empty FEL.
There are a number of other ports where a pressure gauge can be hooked up. Basically anywhere that there is a relief valve, a pressure gauge can be hooked up. That is why the Amazon gauge kits come with so many adapters, gauges, & hoses. There are lots of relief valves identified in the WSM. One of them is not doing its job. It should pretty obvious because it should be hot and rattling and squealing.
We never did ask what hydraulic oil was used to replace the old when you replaced the first filter? Can you find a can and copy the label? Old hydraulic oil is sort of milky and stringy if it has gotten water in it.
   / BX24 blowing hydraulic filters #40
Pretty late to the party here, but looking at the WSM for my BX22, the filter is in the HST Loop. I would expect the problem to be stuck check valves in the high pressure relief valves forward/reverse. Nothing to do with loader relief valve. They are located, looking up from the bottom of the tractor, between the filter and the front PTO shaft.
2020 DRAGON ESP...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55315)
2023 New Holland...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
Portable Restroom (A54865)
Portable Restroom...
1995 Rinker Captiva 190 (A55315)
1995 Rinker...
