BX2360
/ BX2360 #1
Daryl
Southwest Virginia
New Holland TC30,, Kubota Bx2360
Dealer priced me a BX 2360 with 60 in belly mower for $9850 new. Think I am going to buy this for my mower. Does this sound like good price?
/ BX2360
Big choice now is which tires. I am going to put fluid in all 4. I am more then likely just going to use it for mowing. I have a TC30 with loader for everything else.
/ BX2360 #5
good price, get it
/ BX2360 #6
Thats about $800 less than I paid for my BX2350 a year ago. Sounds like a good price. You might want to pass on filling the front tires. It doesn't add that much weight and there was a thread a couple weeks back about someone having a problem with filled front tires.
/ BX2360
Did search and did not come up about problem. Do you rem what it was?
/ BX2360 #9
*Does this sound like good price?
Does that *include a 3 point hitch?
* You might want to pass on filling the front tires. It doesn't add that much weight and there was a thread a couple weeks back about someone having a problem with filled front tires.
*Rite on.
*Did search and did not come up about problem. Do you rem what it was?
*Look in the owners manual
/ BX2360
Yes it includes 3 point hitch..
Also I am not putting a loader on this tractor. Have a lot of hills to mow and thought loading the front would help. Cost is same loaded or unloaded in my deal. Same as choice of tires. Still not sure which tires to get, turf or industrial.
/ BX2360 #11
That is a very good buy. Do it but don't fill the front tires, I get that from all the research thru threads that I have read. I'm looking at getting BX 2660RV, that about the same one U have with 3 more Horses under the Hood.
/ BX2360
R4 indus tires would be better if my land is hilly,right. I have to decide today between turf and R4.
/ BX2360 #13
I get rear tires filled R4's on my B's with FEL. I have turfs on BX's. Have never had BX turf tires filled. I mow with my BX and it is very stable with the turf tires. I have hillside acres in south central Ky. Just don't get on wet grass on hillside with any tires. You'll be surprised how uncontrollable a tractor can be when sliding down a hillside. I only did it one time.:D My hillside is the white house on top of the hill in the middle.
/ BX2360
Just called and told them to deliver it. turf tires with rear loaded.
Thanks for all the help.
/ BX2360 #15
You know the rule. Send some pictures when you get it before you get it dirty. Think you will be totally satisfied with your Kubota. There's plenty of power and can climb any hill without hesitation as long as it isn't so steep it turns you over backwards.:)
/ BX2360
To late... Already dirty but will get some pics.. thanks for all the help. It will go good with my TC30.
/ BX2360 #17
If your front end seems a little light, check into adding suitcase weights or similar on the front. You may need a bracket for them.
/ BX2360
I have looked everywhere in manual and cannot find recommended RPM to mow at. Does anyone know?
/ BX2360 #19
Usually wide open, about 3200rpm. You might want to back it down a little for the break in period, and change the rpms now and then.
/ BX2360 #20
1*Just called and told them to deliver it.
2*turf tires with rear loaded.
Congrats
I have looked everywhere in manual and cannot find recommended RPM to mow at. 3*Does anyone know?
1*Congrats.
2*Only thing I'd of did different is AGs and no filled tires.
3* I just set speed fast enough it don't lug and slow enough it don't soulnd like it's racing.
Any where in that range works for perfect on both my BX23 and BX1500s
(3) 7.5 HP MOTORS (A64280)
(3) 7.5 HP MOTORS...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2000 Kubota KX121-3ST Mini Excavator (A61572)
2000 Kubota...
1985 23ft Mako Center Console Boat with 2011 28ft HMDE Trailer (A61574)
1985 23ft Mako...
2023 NISSAN ALTIMA SEDAN (A59912)
2023 NISSAN ALTIMA...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
