Buying Advice BX2360 vs CS2410 for 60% mowing
   / BX2360 vs CS2410 for 60% mowing #41
We'll have to work on training the kids to leave the racing for the iPods :)
Comparing the BX-70 series with the BX-60, I don't care for what they did with the ROPS. Yes it's foldable but it's wider and taller when it's there. And the choice of fold point seems a bit strange. It's so low that if you fold it you're not left with any protection at all. It might as well be off.
If we decide to buy new it will be the Kioti.
Can anyone comment on life expectancy for the BX2360? The used unit we're considering has I think 480 hrs on it. Is that 25% life? 10%? How long until major components start failing?
A couple of comments:
ROPS: Curious why a wider/taller one would be objectionable. Wouldn't that afford better protection and more room for the operator? Also, any partially deployed ROPS gives little protection and may actually add to the risk of injury. Sorry to sound "preachy", but getting the ROPS deployed fully is an important habit to establish, especially if you're teaching your offspring to operate.
BX life expectancy: Hard to say. The BX's didn't come out 'til about 2000; there are still many early 'Bota's from the 1980's going strong. The major components are comparable to the earlier models, so their life expectancies should be similar. Of course anything can be brought to an early demise with enough abuse, so due caution is always needed with used equipment. Our BX is at 800 hours, has given zero problems over 8 years and operates as new. With proper care, there's no reason one couldn't last for much more than that.
Sickle mower: Don't know if you're going to find one to fit one of these little tractors. Even if you did, I'd be concerned with how close it would be to the operator in the raised position. Would a rotary cutter (probably 48") work?
The Kubota would probably hold its value better over time, but either brand should make a good unit for your needs.
Thanks for the input, Grandad4
I'm very happy with the ROPS on the BX-60 series. I think they got it right. As you mentioned, mowing with the ROPS not fully deployed is a concern. What I like about the old style is the fact that it will fit under more trees without catching on low hanging limbs etc. The new one is taller, wider, bigger and will cause more issues with this sort of thing, I am sure. Making it more tempting to remove it completely... If I don't miss my guess, it's government agencies that are forcing Kubota to go bigger with the ROPS, not realizing that they're actually hurting their cause.
The BX reputation for reliability is top-notch. Your story adds one more happy customer :) Reading back over my post shows how opinions can change "If we decide to buy new it will be the Kioti." Thanks to the advice on this forum to try out the machines. I'm glad I did, although I want to say again the Kioti is a fine machine.
I'm very green on mowing hay. First I have to find out how much of my 2 acre pasture two cows leave untouched. May be I won't have anything left for hay. But if I do, I'll try to get some advice from all the fine folks on TBN on how to get it done! I already have some ideas about using my loader to rake the windrows instead of baling it... Can't wait!!
   / BX2360 vs CS2410 for 60% mowing #43
You can put a 48 inch sickle mower on the BX. On the MMM mower - it shouldn't be making noise - at least it doesnt make much for mine. Do you just slide the lever to full on or do you use the feathering approach? When I am using a heavy inertia PTO like MMM, bush hog, etc, I feather it in. The feathering is hold the pto engagement roughly two fingers or less away from full engagement and wait for things to start turning. Once its turning - I can go full on. The engine doesnt lug this way and hardly makes noise. With my pto tiller - I rarely feather it in as there seems to be little resistance to starting nor engine lugging.
   / BX2360 vs CS2410 for 60% mowing #44
I think you are going to like the BX. They seem to be standing the test of time. 1000 hour 10 year old BX's with FEL are still going for 9 or 10K. I think that says something about the durability.
In my mind the ROPS is there to keep you from being crushed. Most rollovers will stop with the tractor on its side. What good is the additional height even if you do go 180? Maybe if one rolls over onto a rock. Far better to have a ROPS that is fixed and always there.
Making them wider I can see. It may keep the operator from getting crushed under the ROPS.
We just slid the lever full on to start the mower. The feathering is a good idea which I will try.
   / BX2360 vs CS2410 for 60% mowing #47
The ROPS is actually supposed to stop the tractor from rolling all the way over. It's tall so that the tractor stays on it's side. I'm going to guess that there's some math put into designing the height, after all, less steel = more profit for that type of part.
   / BX2360 vs CS2410 for 60% mowing #48
More height on the ROPS may be so that they use the same ROPS for machines with backhoes to give the operator a little more headroom when running the backhoe.
Aaron Z
   / BX2360 vs CS2410 for 60% mowing #49
Aaron Z
If there is a logical reason I would say that this is it.
I wonder if anyone thought about what happens when the operator drives under a tree, the high ROPS catches a limb, the tires keep on a-drivin', and the tractor flips backwards. Sort of like how Absolom met his end... :)
   / BX2360 vs CS2410 for 60% mowing #51
Wouldn't happen. Having done something similar with the garage door frame, I can say that if there is traction, the nose will start to go up, but unless you take the tree branch at chest height, the change in angle will make the ROPS lower to the ground which will let it slip under the branch and drop the front tires back to the ground before you roll over.
Aaron Z
Bet it scared you LOL Good point.
   / BX2360 vs CS2410 for 60% mowing #54
I was bringing my motherinlaw's window AC unit into the garage in the bucket of the B7500 and forgot that her garage door is too short for the B7500 with the ROPS up...
My wife was spotting me and stopped me when the front wheels were ~6" off the ground at which point, I slowly backed up until they were on the ground again.
Aaron Z
   / BX2360 vs CS2410 for 60% mowing #55
   / BX2360 vs CS2410 for 60% mowing #56
The local utilites in all their wisdom bracketed the overhead door on my shop with a pole on one side and 2 guy wires on the other. But who dun it gets complicated. The power company put up the pole and a guy wire that was clear of the door if a bit close. Then the phone company came along and strung a 2nd guy wire below the first and closer to the door. I have caught the 2nd guy wire on the ROPS a couple of times and not always in a gentle way. Do not think I will ever get close enough to it to pin my had between the ROPS and the guy wire :)
Yup I love ROPS. Enough people got crushed mowing so I do see the need.
   / BX2360 vs CS2410 for 60% mowing #57
Pretty much all of the tractors sold today are very reliable. When I bought mine the warranty wasn't high on my lists of things to worry about. Probably the most important part is finding the tractor that fits you. Each one is a little different. Sounds like you found the right one for you. Congrats.
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
Kubota B2301 (A53317)
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
John Deere 4510 (A53317)
John Deere 4510...
