Ballast BX2360 Ballast options and total weight
   / BX2360 Ballast options and total weight #21
I used a smaller than 55 gal. drum to make the ballast for my BX, filled it with concrete and painted it the wrong color. The smaller barrel fits nicely behind the tractor, not sticking out too much. If I recall correctly it weighs about 400 lbs and makes a big difference when doing heavier (for the BX) loader work. I can take measurements if you like. I figure if I need more ballast, I can add weights to the top of the barrel.
   / BX2360 Ballast options and total weight #22
I also have a damp back yard and therefore did not load the tires or put wheel weights on my BX2200 and used it for years. When I sold my 2200 to get the 2660, I decided to add wheel weight as the cost was about the same as fluid and flats easier to repair. I also reasoned I could more easily pull the weights off if I didn't like the added weight.
I have yet to pull the weights and the added weight helps stability without any additional damage to my yard over the unweighted 2200.
so would you get the loaded tires next time?
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
PALLET OF SHLEVING, RACKS (A58374)
PALLET OF...
2013 CIMC REEFER TRAILER (A58018)
2013 CIMC REEFER...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
LOT: Shop Tools: (2) Sets of Truck Ramps, Pittsburg Creeper, Step Stool, Road Cones, Rolling Stool (A59076)
LOT: Shop Tools...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
