Ballast BX2360 Ballast options and total weight
   / BX2360 Ballast options and total weight
I may consider 50% Rimguard at the 50hr service, I know that this may sound strange but I know for a fact that 375 or so lbs in the particular 1/4 acre of my property is the difference between light tracks and ruts. I inadvertently tested that (difference in weight between tractor MMM, and tractor, MMM, FEL) and since that was in the same day within a couple of hours I would say it's the tractor weight instead of a change of soil conditions. This is a preference in my case since I have the luxury of the choice (no extensive hills, almost completely flat, really only one on the driveway and that's the one I had problems with - rear 3pt ballast would have been better in that case anyways).
Honestly up until the other day my FEL was only used lightly, I bought the tractor just before the end of last years mowing season, and didn't have to move any deep snows during the winter (luckily). The project I had was done in response prevention of basement flooding (worked by the way), and had to be done quickly in response to flood warnings (my pile of dirt just defrosted for the first time since I had it delivered, nothing like rain then a perpetual freeze...).
Anyways thanks for the responses!
   / BX2360 Ballast options and total weight #12
My Woods backhoe works well, as does my Gannon box blade, which is commercial grade and weight in a small width. I have it rigged such that I can add a batch of old disc free weights that I bought really cheap on Craigslist. I could use my carry-all with a homemade frame to attach a bunch of those barbell weights.
When I mow with my BX, I need it to be light. For this reason, I would never load my tires. The turf can support the weight as is when damp, but would not support anything heavier, but that's just my clay topsoil that gets waterlogged because the Duripan below doesn't let the water perc down. Other types of soil and better slope/drainage make this not an issue for many BX owners.
   / BX2360 Ballast options and total weight #13
I have loaded tires on my BX1860 and would not have it any other way. A ripper across those wet areas, then level and reseed the grass would improve the drainage. Anothe possiblity is a french drain or modified French drain to carry the excess water away.
We have WONDERFUL RED CLAY in our area, and if it dont drain, it turns to a pit full of mud.
   / BX2360 Ballast options and total weight #14
If I were you, I would reconsider your thinking. I am too in the exact same boat as you. I bought my BX since it has 4 wheel drive so I can mow the wet areas. On one side of my house it wet alot during spring and fall. I didnt want the liquid ballast in fear of making it too heavy.I had tractor over a year without liquid ballast and now it's filled. I found that having extra ballast is great in those wet areas as it helps to plant the tractor more squarely to drive thru the wet stuff when mowing- less damage IMHO. I mow mostly on clay soils. I am sure you will get very tired of swapping wheel weights between seasons and when you do need the ballast but you dont-- what are you gonna do?
You wouldn't catch me without liquid ballast on my BX as I am a firm believer.
I learned that NOT mowing it often is best cure in wet area. I just drive around wet areas and when drier months comes, the BX has plenty of power to mow those areas down.
   / BX2360 Ballast options and total weight #15
You're probably only adding about 100# per tire. Around 10 gallons of ballast/tire.
   / BX2360 Ballast options and total weight #16
I also have a damp back yard and therefore did not load the tires or put wheel weights on my BX2200 and used it for years. When I sold my 2200 to get the 2660, I decided to add wheel weight as the cost was about the same as fluid and flats easier to repair. I also reasoned I could more easily pull the weights off if I didn't like the added weight.
I have yet to pull the weights and the added weight helps stability without any additional damage to my yard over the unweighted 2200.
   / BX2360 Ballast options and total weight #17
I bought this BB for $25 couldn't walk away form it for that amount. Fill it with 15-25 lb rocks, able to add of subtact in a few min. I know it wasn't always orange.
   / BX2360 Ballast options and total weight #18
Same here. If I drive through those places when saturated, it does to the soil what an extruder does to pasta. If I am patient and wait until it dries, the BX cuts it right down regardless of how tall it's grown.
   / BX2360 Ballast options and total weight #19
Mud used to be so much fun to play in as a kid! :cool2: (Sorry Mom.) I guess you know you're not a kid any more when mud goes from fun to nuisance! :(
I do have French Drains along the house foundation, along with long downspout runs. Had to do that after we developed a pond in the crawlspace! :eek: Some of the lawn is contoured. Some is flat and even though I have installed drains in it, it still has spots that I just have to avoid until we set into dry season. Oh well, I still love my BX. First cut of the year on my old MTD garden tractor would take 5 hours, endlessly clogging the deck. The BX just plows right through in 45 min.
   / BX2360 Ballast options and total weight #20
If the OP is still set on a ballast box, Kubota offers one for a farily reasonable price that'll fit the BX. I got one with the purchase of my BX. It's compact, fits the 3PH just right and it's the right color.
More info coming soon! (A55851)
More info coming...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2019 CATERPILLAR 226D SKID STEER (A52709)
2019 CATERPILLAR...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
SARLO MOWER (A55758)
