BX2360 attaching mid mount mower
   / BX2360 attaching mid mount mower #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Ok can any one tell me if there are any "tricks" to getting this thing on the tractor? I'm having a terrible time getting the shaft onto the PTO, specifically getting the collar to lock in place. It's taking me... 15 mins or so to get the deck on and I'm using far too much profanity. Just following the user manual instructions right now.
   / BX2360 attaching mid mount mower #2
Yep, it's a PITA. Can't give you any tricks other than patience. It's the nature of the beast (MMM) and little space to work in. Make sure the spleen is nice and clean and oiled and the locking collar is oiled. I spray mine with WD40 prior to attaching. Gotta do mine this afternoon. On mine (RCK54 22BX), the two piece drive shaft on the mower only goes together one way (but your's may be different).
Good luck,
   / BX2360 attaching mid mount mower #3
I wouldsuspect your 2360 is very similar to my 1850 so the three tricks I use are:
1) before putting the deck under the tractor make sure the PTO shaft telescopes smoothly. If it doesn't pull it apart and clean/ lube it until it does.
2) Make sure the male splines on the tractor are clean and free from mud, crud, etc.
3) Put the deck under the tractor approximately in position. Connect the PTO shaft and then attach the deck to the lift linkage.
By doing these three steps I found it is much easier and significantly less profanity required during the install.
As a side note: Can you rotate the gauge wheels on your 54" deck 90 degrees to help roll it out from under the tractor? If yes do they clear the lift linkage. Reason I ask is that on my 1850 I had to drill new holes to get the deck to clear the lift linkage. This also made the task much easier since it lowered the deck a couple of inches which equates to more arm room for attaching the PTO shaft.
Good luck
Roy
Good luck
Roy
Roy,
Yes, I can rotate the gauge wheels. I like the earlier tip about using WD-40 - I will definitely try that.
   / BX2360 attaching mid mount mower #5
Why let the lift arms down before you hook up the pto shaft? Try letting them down after, that should give you more room to hook up pto shaft.
   / BX2360 attaching mid mount mower #6
Oldnslo pretty much hit it on the head. I've taken my deck off and on several times, and if I timed my self, it wouldn't suprise me if it took 15 minutes total. I tell people it isn't really hard, just akward getting the PTO hooked up.
   / BX2360 attaching mid mount mower #7
I keep two 4' long 2x6 boards in my garage and drive the front and rear wheels of my BX up on them to gain 1.5" additional clearance. Makes manuvering the deck under and into position a little easier. I also hook up the PTO shaft first, then the lift linkages. Finally, if you put the PTO selector in the rear PTO position, you can free-wheel the mid PTO to aid in lining up the splines. Still the hardest part is getting them aligned.
   / BX2360 attaching mid mount mower #8
I have BX2200. I always have FEL on when I change mower in and out. SO much more easy. Lift the front end of the tractor up and you have a lot more room for slide the deck in and out and connect the PTO. The FEL just takes a couple of minutes to put on and off so is not an issue.
   / BX2360 attaching mid mount mower #9
My tips is gonna be different then others.
I find that if the locking collar is greased up, NOT wd40'd it the easiest way.
After spending 5 mins hooking up the MMM to mount points and turning wheels back to travel position, I hook up the mid PTO shaft last.MAKE SURE the pto is selected for rear pto before getting under tractor!!! This allows for finger spin of Mid pto. With mower deck at the lowest position, approach from the left side move shaft a little more then halfway then slide collar back to it "bumped lock".. Then holding the upper shaft and not the collar with left hand (the collar might be crooked but when mating up the coupling you just move down in swift motion just before sliding on. When hand is on shaft and it is used to rotate the shaft, it will "find" the splines to mate. If the splines wont mate after rotating one way and other from flicking wrist, I put down and spin mid pto with freed hand and try again. check locking collar cocked back and try again.
Sorry about long post, but after nearly 4 summers of on/off its best way I can describe it. Time will teach you how to do it easily. good luck! :thumbsup:
   / BX2360 attaching mid mount mower #10
Just an observation, but when you start to see threads on hooking up the MMM, Spring must not be too far off, at least in some southern parts of the country. :thumbsup:
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A53472)
Koyker Loader...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
JOHN DEERE 1050 TRACTOR (A51247)
JOHN DEERE 1050...
2022 KMC 21-37-HD LOT IDENTIFIER 164 (A53084)
2022 KMC 21-37-HD...
2025 INDUSTRIAS AMERICA 227T 7' X 22' HYD TILT TRL (A51247)
2025 INDUSTRIAS...
