3-Point Hitch BX2360 2011
/ BX2360 2011 #1
Rfisher7381
South West Michigan
Kubota BX2360
Is there a way to set PTO height? I am using a rotary cutter 4 ft, and would like to reproducibly have the PTO return to the same height. Really just a PTO stop. I have the mmm PTO set to top. Thanks
/ BX2360 2011 #2
Your question is confusing. The TOP setting on the MMM is for the height of the deck itself. The driveshaft has a universal joint on each end and slides to lengthen or shorten as you raise and lower the mower. The PTO doesn't move.
Same on the rear end. The PTO doesn't move, the 3pt arms are free to travel full distance up and down. There is no where to make the 3pt stop at a set height. What you can do though is add some chains off the 2 dog-ear loops just inside the tail lights down to the 3pt arms. This will give you a bottom limit for your hog.
John Deere 4650 Tractor (A64047)
John Deere 4650...
WOODS TS1680 - 14' ROTARY MOWER (A63290)
WOODS TS1680 - 14'...
John Deere 145 Lawn Mower (A63116)
John Deere 145...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
EZ Trail 3400 (A63118)
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
