BX2350-which implements actually fit?
   / BX2350-which implements actually fit? #1
DEERFIELD
BX2350
Recently rented a knock-off version of a 5' York Rake attached via 3-point hitch and was less than satisfied with the results, i.e. the rake "rode" the soil rather than digging in 1"-2" as claimed.
Mentioned same during a visit to my dealer to perform some window shopping for an aerator, dethatcher, etc. and was astounded to be informed that many of the "estate series" products offered by Woods Equipment and Land Pride are simply too heavy to function effectively behind a BX2350. Instead, it was suggested I consider products from Brinley, Agri-Fab, etc. Not exactly what I had in mind. Left unanswered by the salesguy was the simple question-"How heavy is "too heavy?" My concern is that I have a $16K lawn mower, snow blower and FEL-and not much else.
A different dealer in this area has a radio spot mentioning the "hundreds of tools and implements" that can be used with a BX2350-but this dealer carries next to nothing in stock so comparison is near impossible.
OK, BX2350 owners-the advice, info and comments on TBN are the best guide. What implements (and Model #s)/attachments have you purchased, borrowed or rented which are particularly effective on a BX2350?
When does an implement become too heavy for a BX2350?
Future needs include PH digger (rental), aerator, dethatcher, power rake (Rental), roto-tiller, landscape (York) rake, box blade, etc.
   / BX2350-which implements actually fit? #2
There are a lot of variables to consider:
-the length you have the top link set at affects the angle of the implement as it engages the ground
-the type, structure, and moisture content of your soil Baked adobe is going to be more difficult than sandy loam for your rake.
If your rake is moving but not engaging the ground, then excess weight of the implement is not the problem. If the implement were too heavy then the BX would not be able to pull it. A rake is not a plow. It sounds like you are trying to plow hard packed soil with a tool designed to rake in soft topsoil or humus.
   / BX2350-which implements actually fit? #3
I have the Woods Estate rake and am very satisfied with it. I think your problem is in the adjustment of the rake. I had a 6" rake once, and the BX did a great job pulling the rake. I got rid of it because it was too tall for the BX, but the tractor could handle it. I think you will be satisfied with ant of the "Estate " sized implememnts.
Will
   / BX2350-which implements actually fit? #4
I have a 425lb box scraper that is no problem, though I wouldn't want to drive really fast over rough terrain with the thing lifted. I also have a PHD that can operate a 48" auger, though it can only lift it about 2 inches off the ground. I went with a 42" when I bought my 12" auger for that reason.
   / BX2350-which implements actually fit? #5
The BX2350 is a small SCUT, it's going to have some limitations. I think I've read where rakes work better is loose soil, to clean out things.
Good Luck,
Rob
1993 Trail Boss Lowboy Trailer (A52384)
1993 Trail Boss...
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
John Deere 772-A Grader (A52384)
John Deere 772-A...
2006 Kubota L3130 (A50123)
2006 Kubota L3130...
