BX2350 stalls
/ BX2350 stalls #1
standfas
Friendswood, Texas
Yanmar YM220
BX2350 with 80 hrs dies at unexpected times. It seems to happen more when in low and mowing. It seems almost like a kill switch. The motor just turns off. It will immediately restart. Sometimes it will go for 30-45 mins before it happens again. Sometimes almost immediately. At one point, when I was trying to engage the PTO, it was like turning the key off. I would push the lever halfway down, and the engine would turn off. If I moved the PTO lever back to the off position quick enough, the engine would continue running.
Anyone else with these symptoms or any ideas what to look for?
/ BX2350 stalls #2
The seat safety switch is a common cause of engine stalls. Leaning forward e.g. to watch FEL activity causes the seat to raise, triggering the kill switch.
Another owner had a problem with the PTO safety switch not returning fully causing engine to falter. Lubing solved that problem.
/ BX2350 stalls
I constantly feel like I'm leaning forward in my seat.
Is there kill switch for when the pto is engaged?
/ BX2350 stalls #4
Do you have the newest seat upgrade? Cause that was the feeling I had with the old seat. New seat you actually sit level and is way more comfortable!
/ BX2350 stalls #5
The right hand seat spring sits on a gold colored "Z" shaped piece of metal that is the spring for the seat switch. My BX2350 had 2 of these sandwiched together, but the parts manual only lists 1. I removed one and now it doesn't shut down near as bad going down hills. This could be a safety issue, so use your own judgment as to whether to remove 1 or not.
Briggs and Stratton Generator (A65579)
Briggs and...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2025 58in Padfoot Vibratory Roller Skid Steer Attachment (A64553)
2025 58in Padfoot...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A64556)
2010 Workhorse...
2022 EZ-GO ELITE...
Cat GC25 Forklift (A65579)
Cat GC25 Forklift...
