BX2350 stalls
   / BX2350 stalls #1
standfas
Friendswood, Texas
Yanmar YM220
BX2350 with 80 hrs dies at unexpected times. It seems to happen more when in low and mowing. It seems almost like a kill switch. The motor just turns off. It will immediately restart. Sometimes it will go for 30-45 mins before it happens again. Sometimes almost immediately. At one point, when I was trying to engage the PTO, it was like turning the key off. I would push the lever halfway down, and the engine would turn off. If I moved the PTO lever back to the off position quick enough, the engine would continue running.
Anyone else with these symptoms or any ideas what to look for?
   / BX2350 stalls #2
The seat safety switch is a common cause of engine stalls. Leaning forward e.g. to watch FEL activity causes the seat to raise, triggering the kill switch.
Another owner had a problem with the PTO safety switch not returning fully causing engine to falter. Lubing solved that problem.
   / BX2350 stalls
I constantly feel like I'm leaning forward in my seat.
Is there kill switch for when the pto is engaged?
   / BX2350 stalls #4
Do you have the newest seat upgrade? Cause that was the feeling I had with the old seat. New seat you actually sit level and is way more comfortable!
   / BX2350 stalls #5
The right hand seat spring sits on a gold colored "Z" shaped piece of metal that is the spring for the seat switch. My BX2350 had 2 of these sandwiched together, but the parts manual only lists 1. I removed one and now it doesn't shut down near as bad going down hills. This could be a safety issue, so use your own judgment as to whether to remove 1 or not.
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2025 New/Unused Wolverine Mini Ripper (A51573)
2025 New/Unused...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
Mccormick Hammer Mill (A51573)
Mccormick Hammer...
FAKE (A52472)
FAKE (A52472)
