Mowing BX2350 Spring steep hillside mowing in Ky
   / BX2350 Spring steep hillside mowing in Ky #11
Are those 3 point arms or wheelie bars on the back!!?? Looks kinda scary!!
That's pretty impressive. I have similar hills, some hitting 30+ degrees. After 120 BX hours, I'm still pretty paranoid and back up most. But I have also only mowed with it about 2 hours total, so the rest has been FEL and BH or FEL and RB. I have pretty much zipped around the last 7 yrs. on my lil' 20HP Murray LT and compared to that the BX feels tippy.
Don't have many good "angle" shots of my hills, but here is a couple of my mine...
Do you leave BH and FEL on the Kubota when you mow?
   / BX2350 Spring steep hillside mowing in Ky #13
No, I drop 'em. One because of the COG and two, because there is little enough room to turn around without them. The BX feels much better without them on. I just need to mow more so I get comfortable.
When I first got the BX, I "crawled" everywhere because of the pucker factor. I am much more comfortable now on the hills with the implements on. I just have to go through the same process when mowing, because the tractor feels different without the implements.
I also have a tilt-meter on the hood - so this helps me gauge the risk.
Your post has helped - always good to see others doing it. Went through a similar intiation when I first got the lawn tractor - didn't touch some of my hills till my neighbor came over one day on his LT and zipped around my steep ones light they were nothing. Just a fear factor thing.....:D
Enmark Z Spray (A53316)
Enmark Z Spray...
2012 MACK GU713 (A58214)
2012 MACK GU713...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
