Mowing BX2350 Spring steep hillside mowing in Ky
   / BX2350 Spring steep hillside mowing in Ky #11
Are those 3 point arms or wheelie bars on the back!!?? Looks kinda scary!!
That's pretty impressive. I have similar hills, some hitting 30+ degrees. After 120 BX hours, I'm still pretty paranoid and back up most. But I have also only mowed with it about 2 hours total, so the rest has been FEL and BH or FEL and RB. I have pretty much zipped around the last 7 yrs. on my lil' 20HP Murray LT and compared to that the BX feels tippy.
Don't have many good "angle" shots of my hills, but here is a couple of my mine...
Do you leave BH and FEL on the Kubota when you mow?
   / BX2350 Spring steep hillside mowing in Ky #13
No, I drop 'em. One because of the COG and two, because there is little enough room to turn around without them. The BX feels much better without them on. I just need to mow more so I get comfortable.
When I first got the BX, I "crawled" everywhere because of the pucker factor. I am much more comfortable now on the hills with the implements on. I just have to go through the same process when mowing, because the tractor feels different without the implements.
I also have a tilt-meter on the hood - so this helps me gauge the risk.
Your post has helped - always good to see others doing it. Went through a similar intiation when I first got the lawn tractor - didn't touch some of my hills till my neighbor came over one day on his LT and zipped around my steep ones light they were nothing. Just a fear factor thing.....:D
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2757 (A55787)
2757 (A55787)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
