BX2350 same as BX24?
/ BX2350 same as BX24? #1
samofsweden
Kubota Bx24, 2007
Hi. I have found a company who sell the BX2350 here in Sweden. Tell me if I wrong but isnt (speaking about naked tractor) the BX2350 and BX24 the same machine? In that case I can get spares/service parts for my BX24 here instead of ordering from US (which i really like:D ). Saves me alot of time.
The transmission oil in BX24 are called UDT oil, is there some translation to other oil brands? The manual says only use Kubotas orginal UDT oil:confused:
Thanks for input,
/Sam
/ BX2350 same as BX24? #2
Drivetrain is the same as well as some sheet metal, but specs (capacities) are slightly different. Service parts should be the same.
Of course I mean US spec machines, European machines may be entirely different even though model numbers are the same.
Ok, I better check with sharper eyes then. What I had in mind was filters type of fluids, maybe some spare parts etc. It sounds little vague, but thanks for your input
/Sam
/ BX2350 same as BX24? #4
The frame on the BX24 is much heavier to withstand the forces of the back hoe, but the other components should be the same.
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2000 Hino (A64194)
2000 Hino (A64194)
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
International Harvester (IH) 130 Manure Spreader (A66408)
International...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
JOHN DEERE 925F - 25' GRAIN HEAD (A64277)
JOHN DEERE 925F -...
