bx2350 question
/ bx2350 question #1
crk133
N.W. Michigan
L6060 cab
are you able to operate both raising of the loader and dumping of the bucket at the same time or do you have to do them one after the other?
thanks
/ bx2350 question #2
thanks
Both at same time.
/ bx2350 question #3
Pulling straight back on the joystick should raise the bucket
pulling back and to the right raises and dumps
pulling back and to the left raises and curls back the bucket
Pushing ahead should lower the lbucket
Pushing ahead and to the right should lower and dump bucket
Pushing ahead and to the left lowers and curls the bucket
Pushing fully forward past the detent puts the loader in float. When in this mode left or right movement of the joystick will curl the bucket up or down.
Your loader may have a sticker showing how this works.
The left and right may be reversed according to the hoze hook up.
/ bx2350 question #5
Mine doesn't like that too much. Unfortunate since it is an all-too-common movement, but it simply takes too much pressure to extend all the hydraulics simultaneously. I can only get max lift or max curl pressure when I am doing one at a time.
/ bx2350 question #6
On my BX2200 the manual specifically says it is not recommended to pull back and left due to insufficient lift force. And they're right, it doesn't work worth a darn. I've had no problem with back and right (lift and dump) though.
/ bx2350 question #7
The flow rate and pressures of the hydraulic system on the BX tractors doesn't provide enough to do this movement, so they don't advise you do so. You won't do any harm, but it is like watching a snail move when you do so. Faster to do one movement at a time.
Dusty
/ bx2350 question #8
I agree. You can do both at the same time but it is much slower. And if you are picking up dirt with the FEL it will not allow you to do both at the same time. It simply slows down to a dead stop.
/ bx2350 question #9
Even though the joystick goes in 4 directions. North, South, East and West. If you go Northwest, Southeast ect... the loader will do both at the same time as mentioned.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
John Deere 7R 210 (A64126)
John Deere 7R 210...
