Grading BX2350 Hyd. Angle Rear Blade
   / BX2350 Hyd. Angle Rear Blade
"Bret Mc" No I don't have any check valves or relief valve it is straight off the remote valve on the tractor. And as stated the cylinder is a little over sized and it can bend things if your not careful.
Bret & npalen; As for going over center it uses the momentum of the blade swinging to break it over the center point. When the cylinder is fully retracted quickly shift the valve in the other direction and the blade will keep going in that direction. At the fully retracted point I built in a little slop in the cyl. rod clevis. This allows about 1" of play on either side of the cylinders center line. So when the cylinder is retracting at speed the momentum of the blade will cause the cyl. to break over its center line. And by quickly extending the cyl. it will continue on in that direction. The external stroke limiter is how I fine tuned it. So that when the cyl. is fully retracted it is not pulling the crank arm tight.
I would like to post a video of it in action seeing it work is really cool. I have never posted a vid on here before but I will give it a try.
   / BX2350 Hyd. Angle Rear Blade #12
That makes sense to me now.
Good idea!
Nelson
   / BX2350 Hyd. Angle Rear Blade #13
makes sense to me also, thanks,I look forward to the video, that is a very neat and clean looking fab job, just the way I like my stuff to look (and work) great job.
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2007 Case IH 275 Tractor (A59814)
2007 Case IH 275...
LOT: (6) Office Chairs (A59076)
LOT: (6) Office...
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
