BX2350 FEL Forks - completed
   / BX2350 FEL Forks - completed #1
SkunkWerX
Platinum Member
Central Maryland
Kioti CK2510H
I just finished and used my forks on my BX2350 FEL.
Soicne the BX2350 is on the small side of things, I wanted to keep the forks shorter, yet allowing for picking up things up to about the 500 lb. range.
I used 2x2 square tube, 3/16" thick. They were 4 foot sections, but I ended up cutting off a few inches. from cutting edge to Point is about 30 inches.
Used them yesterday to haul brush and logs in an area I am cleaning up before installing a fence line.
(Also pictured, is the 20 yr. old grader blade I rehabbed, cut from 6 foot wide down to 5 foot, and painted matching color)
http://usera.imagecave.com/skunkwerx/Forks.jpg
http://usera.imagecave.com/skunkwerx/ForksBlade.jpg
   / BX2350 FEL Forks - completed #2
Nice looking machine with plenty of functionality.
Thanks!
Forks for an FEL are an inexpensive add-on, but really high value for the dollar.
I can haul much more (logs and brush) and longer pieces, a real time saver.
Forks at Work
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2021 Kubota SVL 97-2 (A57148)
2021 Kubota SVL...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
40' High Cube Multi-Door Container (A57149)
40' High Cube...
