BX2350 Cheatsheet
/ BX2350 Cheatsheet #1
MoreCowbell
Clayton, NC
Kubota BX2350
After going back to my owner manuals for the 3,000th time to look up frequently used info on my BX2350 (e.g. tire pressure, oil type, etc.), I decided to put it all on one cheatsheet I can thumbtack to my garage wall. I don't know if anyone has put together something like this previously, but I figured I'd post it here for any other BX2350 owners.
Everything was taken word-for-word from the tractor/mower/loader manuals - even the weird stuff (e.g. mixing metric and standard in the loader specs).
Anyway, hopefully this will help someone keep their manuals a little less greasy.
  • BX2350 Cheatsheet.pdf
/ BX2350 Cheatsheet #2
I don't agree with the factory air pressure other then those are the max pressures for those tires. You shouuld always run with a full tire on the ground.
/ BX2350 Cheatsheet #3
I like the idea of a cheatsheet, its a PITA to look up the info all the time...wish I had one for my BX23 and 60" MMM..
/ BX2350 Cheatsheet #5
We're you going to post the cheat sheet? This is a great idea! I would like to see what you have put together and modify as needed for my BX25.
/ BX2350 Cheatsheet
DAT, I attached that file to the original post. It's a PDF file. Can you see it? I can private message it to you if you are having a hard time pulling it down.
/ BX2350 Cheatsheet #7
Is'nt this the same engine thats in the BX 25 and BX 2360 basically the same tractor?:confused::confused:
/ BX2350 Cheatsheet #8
That's great. Any chance you have the original word version to save me some editing time? Thanks!
/ BX2350 Cheatsheet #9
That's great. Any chance you have the original word version to save some editing time. Thanks!
/ BX2350 Cheatsheet
Hello. I should have posted the original Word doc initially. Here it is...
/ BX2350 Cheatsheet #11
This is so painfully obvious, yet I never thought to do this. Thanks!
/ BX2350 Cheatsheet #13
Seriously!
Wish I would have found this yesterday. Just finished doing the full maint and was looking all over for these specs. :mur:
Thanks
/ BX2350 Cheatsheet #15
well done! Need to create one for my BX. Thanks!!! :drink:
/ BX2350 Cheatsheet #16
Yep, well done. I want to do this as a checklist - I'm going to laminate it so I can use a grease pencil to mark off each step needed at recommended intervals. Oil types and weights, how many zerk fittings to lube, what torque for the bolts. Then when it's all done I can wipe it off and use it again next time.
That's the plan, anyway!;)
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
