BX23 (XX?) Light Upgrade
/ BX23 (XX?) Light Upgrade #1
tshep
Richmond, VA
BX23 MLB
OK - My turn/hazard flasher failed.
(I resoldered all the back side stuff - remained failed.)
As you know, it's $100 now.
So, researched VA code, wiring diagram, my use - and decided 'turn signals' were useless on a daylight-travel only tractor.
I also concluded, what are they called, twinker lights, in US market were only there for parts sales.
So,
Twinkers off and into spares, wires taped off nicely.
EF32SS-R attached in place of older 'flasher.
Amazon.com: CEC Industries EF32SS-R Flasher: Automotive
1 thin male spade into connector at Hazard, 1 thicker female spade at flasher (polarity matters, doesn't hurt it).
2 thin male spades into connector at Left and Right, tee-ed to 1 thicker female spade at flasher.
Re-attached hanger bracket, rubber sleeve.
Replaced 1076 style in larger round lights with brighter LEDS.
Amazon messed up the link, but 1076/BA15D search covers it (mine were Jomitop).
I do believe the single lamps now makes more light than both did before, and the flasher works fine with only 2 wires and a minimal load.
$25, should be better for longer!
/ BX23 (XX?) Light Upgrade #2
Yup. Out here in CA. we can get away with just the SMV sign, going around the neighborhood (which, I will have to do coming from the backyard to the front, I'll have about a 1/4 mile of street to run on, when I do any work in front) like the Amish do when they travel public roads.
Pick
/ BX23 (XX?) Light Upgrade #3
To be honest, I've never had occasion to use the turn-indicators on my 4105... that's because, if I'm on a public road, I'll have my 4-way flashers going + an amber 'whoop-whoop' going on top of the ROPS (SMV is also present).
I'm simply observant of traffic/surroundings and use hand signals if/as required.
Volvo L306 (A57148)
Volvo L306 (A57148)
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2015 LAND ROVER RANGE ROVER EVOQUE (A60736)
2015 LAND ROVER...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2019 KUBOTA SIDEKICK RTV-XG850 (A62130)
2019 KUBOTA...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
