BX23 warranty question
   / BX23 warranty question #1
jhb
MA
BX23
I have 2 payments left on my BX23 (168 hours)! Sadly, that means it's out of warranty too. I currently have the following problems:
1. Broken air filter mount. I know, common.
2. electrical: the machine is left out doors and all 3 rocker switches are having problems. The blinker switch keeps the lights blinking no matter the position, the headlight switch has a mind of its own. I unplugged them and to date have not been concerned. Assume its just switches.
However, I should get this stuff all fixed up before April comes around and I lose the warranty. I also am planning on selling it this summer after I finish a few remaining projects.
Heres my problem, I did not buy it locally, and the last time I had the tractor serviced (50 hour) they charged me 250 for pick up and drop off. Can I get this stuff serviced without hauling it to the dealer?
   / BX23 warranty question #2
That would be surprising if they would just hand over new rocker switches as a warranty item without inspecting the tractor themselves. You didn't have a 100 hour service? And no buddies with a trailer? You could take off the FEL, BH, and MMM and put the "bald" tractor in a fairly modest trailer. It is only 1200# at that point.
As an aside, I keep my tractor INSIDE (bought new off a crate at the dealer, so it hasn't seen much moisture) and my headlight switch has not functioned for a month. POS, it would seem.
   / BX23 warranty question #3
jhb said:
... I currently have the following problems:
1. Broken air filter mount...
2. ... all 3 rocker switches are having problems...
JHB, these are problems that can be handled at home.
1-You can easily remove the filter mount. After that, you can show it to a dealer and ask for a warranty replacement; if he refuses, just weld it back together.
2-The rocker switches are easily lifted from the dash; they can then be separated for servicing. Take a look at the metallic contacts inside the switches, and scrape them clean. If that fails, you can always order a new switch from the dealer.
   / BX23 warranty question #4
There was a thread a while back where someone installed water proof marine grade replacement rocker switches... probably only wanted to deal with the problem only once.
   / BX23 warranty question #5
Leaving the tractor out 27/7 has caused the switch problem .
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
New Holland 939 3 Row Corn Head (A50774)
New Holland 939 3...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
