BX23 toolbox project.
   / BX23 toolbox project. #1
Volfandt
TN
2004 Kubota BX23, 1966 WheelHorse 856
Greetings, as all BX owners know, probably the only shortcoming of the BX series (well, to me anyway) is the lack of a toolbox. I guess when Kubota set out to make the 1st ever subCUT, they wanted to squeeze as much into as small a space as possible. This is a good thing in most all respects except'n most of us need a small storage space for the various tools & gloves we need when operating our BX's.
Well, I found a well made, somewhat heavyduty and small tool box of just about the perfect size for my BX23. It's 11x4x4 and weighs a good couple/three or four lbs and has a full length lid hinge. I ordered it on Wed and got it on Sat., and it came red primed, ready for painting.
After peep'n around the BX23 for a space to mount it, I noticed several plastic plugs on the metal seat back frame and when I removed them I discovered the holes had press fit 8MM nuts behind them. There are at least 6 of 'em so I picked the set that would line up with the tolbox's backplate, marked and drilled some holes in the box, test mounted it and saw that it'll just clear all the obstacles and work pretty good. I was then faced my last decision, what color to paint it! Black would have made it blend in with the seat and I almost went that route but I then decided that I wanted to use up the last of my Chev engine orange spray paint and I wanted it to stand out a little too /forums/images/graemlins/grin.gif so orange it be!
It'll hold my workgloves, some handtools, some implement clips and whatever other small stuff I may need once I get to working this little beast /forums/images/graemlins/grin.gif
Heres a shot of the toolbox fresh out of the shipping box in it's red primed glory.
Heres a pic of it mounted on the seat. The two 8mm 1.25 bolts secured it good enough and lockwashers & locktite should hold 'em thataway.
A pic showing how it clears the steering wheel when the seat is in the BH position.
   / BX23 toolbox project. #4
OK, where did you order it from? Details, we need details.
Good job by the way.
A final pic showing how it clears the ROPS by a just couple inches when spinning the seat around. If I had mounted it an inch lower it wouldn't have cleared the ROPS.
All in all the toolbox fits just about as good as any would have and I'm not so sure that a longer, taller or wider toolbox would have worked behind the seat.
Volfandt
DannyD, I ordered it from Alpha Tractor Services which I found on the ytmag parts website.
Heres the link.
toolbox
Whilst sitting here admireing my new orange toolbox, a couple of my neighbor's snowwhite female turkeys decided to stroll on down and peep out the BX also. There's also a big Jake but he doesn't get to close to folks except when my wife stops to get the morning paper and then then does is display and struts towards her. She say's he gets pretty aggressive and I tell her that he's just trying to impress and hit on her /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Volfandt
This is too funny. I took the BX on down to turn the compost pile and then cruise the back 40 and afterwards I put it up back in the shop. Well those turkeys must really like that orange machine as they came back and then just waltzed right on in to the shop and hung around the BX for awhile. Since they came so close to me I was able to tell that one is infact a young Jake whilst the smaller one must be his main squeeze. They kinda hung out awhile, checking out the shop then sashay'n back to the Kubota. They never got on it but they sure hung round it awhile. What the hey, if'n they hanging out in the shop I 'll let 'em, that is until they start poop'n or the like then I'll have to bid 'em adue /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
The young Jake
The lady, I rekon....
   / BX23 toolbox project. #10
Looks like dinner to me /forums/images/graemlins/grin.gif Nice looking tool box mount. Do you think the weight will be an issue on the seat back when bouncing around?
2019 Doosan LCV6 Towable Light Tower (A51691)
2019 Doosan LCV6...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2015 ISUZU NPR 16FT BOX TRUCK (A52141)
2015 ISUZU NPR...
Bobcat 15 Skidloader PHD (A50774)
Bobcat 15...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
