BX23 stalling, must be the feul sending unit rust thing...wrong!
   / BX23 stalling, must be the feul sending unit rust thing...wrong! #1
Berniep
Platinum Member
Greensburg IN
2005 BX23
Havent been around here in a while but when my tractor started acting up the first thing I did was search here.
The symptoms matched exactly the folks who found rusted fuel level sending units. Stalling, sputtering and such.
Seat switches check good with an ohm meter.
I could see trash in the first filter
Sooo after two and a half hours of dissasembly I had the tank out.
And what do you know
PERFECT!!
crap:mad:
I was sure that was it. But I know I would always wonder if the sending unit was rusty or not. And I rinsed out the tank good anyway.
I replaced both filters and hope that was the problem.
That's pretty much all I found in a search was the seat switches and the rust thing. If anyone has other suggestions of things to check let me know.
   / BX23 stalling, must be the feul sending unit rust thing...wrong! #2
Jeez, was that really 3 years ago? (Just looked at the date of your previous posts.) Well, now that you got her apart, might as well change all the lines in case there's a slug of something in them.
How bad and how often does it sputter?
I had to modify my seat switch to keep a good connection (I weigh 140 lbs... Don't let the name and weight confuse you...I'm a guy.)
If it runs consistently bad, you should be able to do a quick flow check. If it's intermittent, then it's gonna' be hard to spot with a one-off check.
   / BX23 stalling, must be the feul sending unit rust thing...wrong! #3
The filters are so dinky on the BX's it doesn't take much to plug them up. Probably just a little dirt in your fuel. On mine, I could never figure out if my filters were gelling up or just a little bit of dirt was getting in them and plugging them up. I mounted a Racor unit and that fixed it. If you keep having problem mount a Racor or some people use the setup of a B sized tractor.
   / BX23 stalling, must be the feul sending unit rust thing...wrong! #4
On my BX25, only enough, it was from a partially stuck brake. I thought for sure it was a fuel related problem, but once my dealer fixed the brake, the sputtering and stalling I had to deal with disappeared entirely.
Update: I haven't run it a lot but I did spend an afternoon with the rotary mower and no problems, so it seems like I got it fixed.
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
FUEL CELL (A58214)
FUEL CELL (A58214)
2015 Kenworth T880 QMC 8060R 50 Ton Tri Axle Crane Truck (A60460)
2015 Kenworth T880...
Landoll 876C Soil Finisher (A59814)
Landoll 876C Soil...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
