BX23 power loss
/ BX23 power loss #1
AHNC
Nevada City CA
Kubota BX 2660 & BX-23
I have about 450 hours on the machine and it has recently lot power on the drive train. I had a heck of a time getting up a slope that It has been up many times without issue. Suggestions?
/ BX23 power loss #2
Is it only when on a slope that you lose power? If so, my first guess would be that you need to change the fuel filter. Same thing happened to me. Water gets trapped in the filter and when on a slope the water moves inside the filter and obstructs fuel flow.
/ BX23 power loss #3
Here's another vote for changing the fuel filters. This is a frequent subject of discussion here. Of course I would be remiss if I didn't mention that the parking brake being left on and / or the speed selector set to high instead of low can cause this as well.
Sent from my iPad using TractorByNet
/ BX23 power loss #4
Two votes for the filter so far. Not trying to insult, but do you have it in the low range? Every now and then I think I have lost power and realize I forgot to shift out of the high range. One other time when I seemed to be losing power it was because the pedal linkage was coming loose so I wasn't getting full range. Could be the filter, but check the really easy fixes first.
Doug in SW IA
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A59230)
1987 International...
2013 Ford Explorer SUV (A59231)
2013 Ford Explorer...
2001 Crosley 20FT T/A Flatbed Equipment Trailer (A59230)
2001 Crosley 20FT...
Attention (A57148)
Attention (A57148)
