BX23 loosing power after 10-15 mins of use
   / BX23 loosing power after 10-15 mins of use #1
wfd2
Michigan
IH 656 Diesel
I have a BX23 that is loosing power after 10-15 minutes of use. Sometimes it is so bad that it wants to stall trying to move the tractor.
1. I replaced both fuel filters.
2. There is good flow on the tank side of my first filter (just ask my shirt!).
3. I added fresh diesel fuel from a station that sells a lot of it (I put the same fuel out of the same can in my RTV900 and it's fine). However, there was a time when the tank was < 1/4 tank for long periods of time before this problem started.
4. When I replaced the filters, they did have some water in them. But they had 150+ hours on them too.
5. I also checked the filler cap vent by removing the cap when the engine was sputtering, effectively venting the tank. No change.
Any suggestions are welcomed!
wfd2
   / BX23 loosing power after 10-15 mins of use #2
wfd2
Wow that's a mystery. Does it matter wether whether the tractor is under a load or not?
Sent from my iPad using TractorByNet
   / BX23 loosing power after 10-15 mins of use #3
You mention moving the tractor, does it idle and throttle up ok? If so, I would check the hydro screen, and change the hydro fluid and filter perhaps.
   / BX23 loosing power after 10-15 mins of use #4
My L3240 did something similar and it took a few months of searching to find the cause. Mine got so bad it blew white smoke from time to time. This all started after I changed my fuel filter because the one on it was installed wrong.
Seems the auto bleeding doesn't always work correctly and you can get air into the injection pump. A diesel injection repair shop actually told me about the problem and why each time I played around with it I was making the issue worse. Always would happen after the tractor had run for 10-15 minutes. The pump is "emissions certified" and doesn't bleed air once it's in it most of the time. If you loosen the nuts on top of the pump it can screw it up, but that is one solution to bleed it. So what they said I could try was to get the tractor on a slope, pump on the up side of the slope. Then open the bleed screw and let it sit for a while. I did this 3-4 times and had the front end both up and down slope. I would also start the tractor with the bleed screw open shut it off and let it sit some more.
The reason for parking both up and down slope slightly is the pump is bored at an angle to get to the 3 injection ports.
This finally worked and now I have put 40 trouble free hours on the tractor, after 20 hours of poor running and working on the tractor.
I hope I explained this clear enough.
Hi Bob,
It doesn't matter whether it's under load or not. In fact, when this is happening I can't even throttle up sitting still.
Tollster,
This happens when the tractor is sitting still as well. It won't throttle up when this is happening.
Are you hearing the fuel pump clicking when turning the key and before starting?
Yes, I am. Runs fine for 10-15 minutes then starts to loose power. If I turn it off and try to restart it, it will start but it will continue to sputter. After it cools, it will run again for 10-15 minutes and the cycle starts all over again.
There is an electronic lift pump under the BX23. If this pump is failing when it gets hot (maybe after 10-15 mins of use) would the tractor exhibit this behavior?
   / BX23 loosing power after 10-15 mins of use #10
I was thinking the same thing. Depending on failure mode I don't know if the main injector pump could pull fuel through both filters and the bad lift pump. When it starts acting up could you pull the hose off that feeds the injector pump and just turn the key to on and see if the lift pump is moving fuel.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2014 VOLVO EW210D MOBILE EXCAVATOR (A60429)
2014 VOLVO EW210D...
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
