BX23 HYDRAULICS
   / BX23 HYDRAULICS #1
KATHYPAINT
BX23 HYDRAULICS SUDDENLY FAILED PLENTY OF FLUID NO BROKEN LINES MOWER LIFT IN NUETRAL WAS SERVICED ABOUT TWO WEEKS AGO EVERYTHING WORKING FINE FRONT BUCKET WILL WORK VERY VERY SLOWLY BUT MMM AND BACKHOE HAVE NOTHING ANYONE HAVE IDEAS THANKS
   / BX23 HYDRAULICS #2
Welcome to TBN:D
First-Please turn off your caps lock...it is considered yelling and is very hard to read.
Now, on to your problem...
Does the engine sound labored? If so I would unplug the reconnect the QD's (quick disconnects) on the two hoes that feed the backhoe...sometimes they come unplugged just a little bit causing the hydraulic fluid not to flow.
   / BX23 HYDRAULICS #3
Also make sure the 3pt/mower lift lever is in the middle position. Mine doesn't auto reset to middle anymore(to lazy to look at/adjust).
   / BX23 HYDRAULICS
Sorry for the caps. Yes mid mount mower lever is in the middle. Was in the middle of the field working and everything just quit. I will try disconnecting and reconnecting the couplers but they all seemed connected.
   / BX23 HYDRAULICS #5
You would be surprised how many times I have heard that! They can "look" connected but not flow any fluid!
   / BX23 HYDRAULICS #6
KATHYPAINT
What Stargazer said
Raise 3 point lever till arms come up all the way and push it down have some one push them down and set the lever in the middle of the two positions.
check the loader and hoe functions another thing it to check the back hoe connections that they are all the way connected
If that dosen't work
turn tractor off put loader bucket down and hoe bucket down on ground.
move the loader lever up and down (loader shouldn't move) and unhook the hoe hoses and hook the tractor lines together.
start tractor try the loader again shut tractor loader down move loader handel up and down to releive presure hook the hoe back up.
start tractor again and try functions
tom
   / BX23 HYDRAULICS
Ok tried the Qc disconnect and reconnect No luck. Does seem to be a sound like maybe the pump is running or hung up Does this give another clue
   / BX23 HYDRAULICS #8
Is it cold were you are? could be water in oil frozen
pull dipstick and check level is it low?
look at the color too
if you need oil only use sudt oil
mine acted the same and the 3 point lift control was stuck in the up position
and I didn't notice it
check the linkage on it valve is under fender follow the linkage
check the knob for the lift speed put it in the middle of the range too
tom
   / BX23 HYDRAULICS
No not cold here yet. Plenty oil just serviced couple of weeks ago. 3 pt lift centered. Not sure where valve is , schematics might ne helpful. Thanks so much for help.
2014 Ford Transit Connect Van (A50323)
2014 Ford Transit...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
