BX23: Front TRX axle oil/did I mess it up?
   / BX23: Front TRX axle oil/did I mess it up? #1
jhb
MA
BX23
I had my BX23 serviced last week. I decided to check all the fluids in the tractor when I got it back. Most fluids were 1/2 between the high and low mark. Seemed a little cheap that they were not topped off. I checked the fluid in the rear under the seat, and the engine oil.
However, when I checked the fluid in the front axle, It would not touch the stick. Very low. I would assume they would have looked at this, seeing as the service cost me 300 bills plus 200 for transporting the tractor to the shop. I looked at the service receipt, but no mention of the front axle fluid. So maybe its not part of the 50 hour?
Anyway, it was Sunday, and I was concerned about operating the tractor with the fluid so low, so I went and looked it up in the Manual. It said I could use sae90, sae80, or super UDT fluid. Well, I do not have any super UDT fluid (soon to be remedied for top offs). There is a boat supply store near by so I went in and got a tube of SAE90 lower unit gear oil. Figured it's the same thing, right? Is this OK?
I filled it to the top of the level stick. I went to check it after an hour, and the fluid was under pressure and sprayed all over the place. Is THAT normal too?
Did I mess up by mixing fluids? Should the dealer be held accountable? TIA
   / BX23: Front TRX axle oil/did I mess it up? #2
I would say it is not part of the normal service at 50 hours. I think it is not due till like 200 or 300 hours.
The BX23 comes with Super UDT in the front axle. So now you mixed the gear and UDT fluid. I personally would drain and install either fluid. I use 75w-90 in my diff but Super UDT is also fine. I know my gear fluid has the same poor point but a better KV at 100C.
Also yes the front diff does get some pressure and that is one reason why I dislike the UDT for a gear fluid. Also this pressure is why some people on the 22 and BX23 have front diff leaks.
This might help you:
old topic on UDT
How bad to leave them mixed for the time being. Wouldn't I just get a viscosity value between the two?
   / BX23: Front TRX axle oil/did I mess it up? #4
not should not hurt anything I feel but I do not know if the two fluids are compatible either. The gear fluid you put it will not have the same pour point unless it is a synthetic fluid.
It it holds like 4 to 5 qts
   / BX23: Front TRX axle oil/did I mess it up? #5
My dealer adamantly said not to mix the oils. They are not compatible. I would drain completely and refill with new oil.
Maybe I'll get some Mobil 1 75w-90. I have some extra lying around from a transmission oil change I did on one of my cars. I suppose that should be OK.
   / BX23: Front TRX axle oil/did I mess it up? #7
I kind of figured that. That is why I said I would drain and refill. Also I also guess it would not hurt anything major like it would in a hyd sys. It is only a front diff. Without knowing both oils, I would drain.
I also find it odd now that Kubota states on there webpage...(stated below)
FRONT AXLE CASE (4WD ONLY) -----GEAR Oil SAE 80 or SAE 90..no UDT listed....weird
Wolverine Quick Attach Stump Grinder (A50515)
Wolverine Quick...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
New Holland L225 Skidloader (RIDE AND DRIVE) (A50774)
New Holland L225...
