BX23 Front loader boom cylinders/hydraulic fitting bent
   / BX23 Front loader boom cylinders/hydraulic fitting bent #1
jhb
MA
BX23
Are the hyrdaulic fittings on the boom cylinders threaded into the cylinder or welded? I bent mine so now the coupling is rubbing the cylinder. I tried to remove the fitting, but it would not budge, and did not put so much pressure on it that I would snap it off if welded. Can I just bend it straight or let it be?
Also, it started leaking from the top of the 90deg coupling. I noticed an allen key head and thus learned that there is a cap on it. I removed it, retightened and all appears good for now. Anything I need to be concerned about?
   / BX23 Front loader boom cylinders/hydraulic fitting bent #2
I would leave it alone, and only deal with it if and when it gets to be a problem. Any type of repair that you attempt might be worse than the problem as it exists today.
2000 Genie Z45/25 Manlift (NOT RUNNING)(TITLE) (A50774)
2000 Genie Z45/25...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
2013 Kubota M9960 (A50120)
2013 Kubota M9960...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
Kubota 2 Cyl Engine (A50774)
Kubota 2 Cyl...
